SV650 - has started stalling at inconvenient moments
Discussion in 'UK Motorcycles' started by Mo, Oct 12, 2004.
  1. Mo
    Mo Guest
    I've got a 2003 SV650 K3 model and as above it ticks over
    nicely but rather slowly, just over 1000RPM but will easily
    stall, hot or cold, usually if not always as I'm slowing down
    and just as I change into a lower gear. This has become more
    pronounced lately to the point where it's annoying, I also get
    the impression that on overrun the engine acts as though it's
    cut out completely.
    I normally just thumb the starter and it fires straight back up
    again although in hot weather - no not recently - it had a
    tendency to die immediately after re-starting.
    Any suggestions or tips gratefully received.
    Mo, Oct 12, 2004
  2. Mo
    AndrewR Guest
    Take it to your nearest Suzuki dealer and ask them to rechip it so that it
    stalls at convenient moments.
    HTH,
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1
    BotToS#5,SBS#25,IbW#34, TEAR#3 (and KotL), DS#5, COSOC#9, KotTFSTR#
    The speccy Geordie twat.
    AndrewR, Oct 12, 2004
  3. Mo
    Ginge Guest
    It's almost winter.... Buy a car.
    Ginge, Oct 12, 2004
  4. Mo
    Christofire Guest
    It's not carb icing, so that's my suggestions from previous ownership
    out the window. Have you made any modifications?
    Christofire, Oct 12, 2004
  5. Mo
    AndrewR says...
    My Firestorm used to stall, most of the time at inconveient moments like
    half way out of a junction.
    Lozzo, Oct 12, 2004
  6. Mo
    Mo Guest
    That has its appeal
    Mo, Oct 12, 2004
  7. Mo
    dwb Guest
    Indeed - and ask them to check the idle speed as well.
    My GSX-R was cutting out at traffic lights because it was idling about
    250rpm lower than it should have been.
    FWIW, the SV (K1) I had cut out too but that was because of a) carb icing
    and b) the exhaust I fitted.
    dwb, Oct 12, 2004
  8. Mo
    Mo Guest
    A vist to the dealer seems to be in order then. Only it'll have
    to be a different dealer from Bikesmart in North Ealing on
    account of they shut up shop about 3 months after I bought it
    from them. Good job it's a manufacturers warranty.
    Mo, Oct 12, 2004
  9. Mo
    muddycat Guest
    I had the same problem with my K1. Turned out it was the idle
    (tickover?) set too low. Mine is set at 1200.
    muddycat, Oct 13, 2004
  10. Mo
    HTF can it stall when you're moving and in gear? The motor might die,
    I suppose, but that's very different from a stall.
    Ace, Oct 13, 2004
  11. Mo
    Ace says...
    It would hiccup and just die. Tickover was set correctly, it had been
    set up on Fowlers dyno after the Scorpions were fitted, but just as you
    were pulling out of a junction and applying a bit of throttle the engine
    would hiccup and die. It nearly went over a couple of times as it used
    to catch me out. I tried everything to stop it stalling, in the end I
    turned the air screw out a quarter turn and that seemed to cure it.
    Lozzo, Oct 13, 2004
