Swinging arm woes
Discussion in 'UK Motorcycles' started by The Older Gentleman, Jul 3, 2004.
  1. Been stymied on the DT50 job.
    Tried to remove the swinging arm today, to strip and repaint it. It is
    utterly seized in position. The main pivot bolt twirls around loosely
    enough, but it's evidently seized onto the main sleeve. Heat (lots of)
    and an assault wiv an 'ammer have had no effect.
    There was a little bit of play in the swinging arm before. There's more
    now.
    So..... I'll have to cut the bloody thing out with a hacksaw (can't get
    The Holy Angle Grinder onto it) and then lob it at an engineer to have
    it reamed out, probably new bushes fashioned (I think Yamaha uses those
    horrible rubber things, and those will have been utterly destroyed by my
    attempts with the blowlamp, so phosphor bronze might be an idea) and a
    new swinging arm pivot either bought or made up.
    Right - does anyone know anywhere near or in SW London that does this
    sort of work?
  2. The Older Gentleman
    CampinGazz Guest
    Dunno about doing the work, but i had the same problem with my TS 125, angle
    grinder got the bugger out in the end.. hack saw wouldent make a dent..
    chromed hardened bolt type thing for the swing arm pivot.
    But once the swing arm was off, i placed it in a vice, and using a suitably
    sized socket to press on the bearings (not bushes in my case. couple of
    needle roller bearings) twatted them with a big hammer, they came out pretty
    easily.. the reason mine was really stuck was the bolt had stuck to the
    bushings that sit in the bearings.. they're 2 top hat shaped bushes, that
    are pushed in from either side,
    one set came free eventualy, but the other side is still one piece.. bit of
    bolt and the 2 bushes, that's why mine wouldent come out the 'easy' way..
    i.e. on the bike.
    This just needed a new set of bearings and the top hat shaped bushes.. no
    reaming or anything, i ordered the bearings, was trying to salvege the
    bushings to keep costs down, and then i picked up a complete swing arm
    whihch had had new bearings throughout recently at newark last weekend.. for
    a fiver,
    Mr suzuki shop wont take the bearings i didnt use back.. so i now have some
    spares i'll never use.... unless anyone else is doing the main swing arm
    bearings on a ts 125 that is :) (that bolt is now coming out every year
    without fail for a good dollop of grease, something the last owners could
    have done but didnt)
    Anyhoo, get the bugger off first and see what the dammage is, when the swing
    arm is in a vise you can usually get the bearings/bushes to move, as when on
    the bike the frame flexes when you hit the bolt, idealy before you cut the
    arm up, you want to find a place with a hydraulic press that can take a bike
    frame in it's jaws, and try to get the pivot bolt pressed out.. that's
    what's usually done with the suzuki's people rekon.
    If my Yamaha want's owt like the price of the suzuki bearings and bushes,
    then go to an independant bike shop, and ask to have a flick through hte
    staniforth catalouge, they sell swing arm repair kits, that comprise of a
    couple of nylon type bushings that replace the bearings and all that, £16
    for the kit for my bike.. better than the £95 for genuine suzuki parts.. and
    i'd have gone that route if i haddent found the swing arm at the auto jumble
    CampinGazz, Jul 3, 2004
  3. Just got it out. Did it with a small single-handed hacksaw, and it took
    about an hour. Bastard job.
    The swinging arm bushes just fell out - they're those horrible neoprene
    things and they'd been well toasted by the blowlamp.
    Hey-ho. New swingarm pivot and sleeve and a pair of new bushes.
    Shouldn't be much.
    The shock came off the top mounting as easy as you like, which was nice.
    Next stage is to strip the paint off the swinger and re-paint.
    The Older Gentleman, Jul 4, 2004
