Syd: Clutch master cylinder repair ?
Discussion in 'Australian Motorcycles' started by david, Sep 8, 2004.
  1. david
    david Guest
    My BMW K1200RS has a minor leak from the clutch master cylinder. A BMW
    service shop has told me that to fix this problem they just replace the
    whole assembly, at a cost of $350.
    This seems a drastic (and expensive) remedy for a minor leak.
    Surely it is possible to dismantle the assembly and replace the
    broken/worn seals which are causing the leak ?
    Can anyone suggest a place in Sydney that would perform such a repair ?
    Thanks
    David
    david, Sep 8, 2004
  2. In aus.motorcycles on Thu, 09 Sep 2004 07:38:59 +1000
    The problem might be getting the seals....
    Start by taking it to a car brake place, perhaps one that specialises in
    modded vehicles. Look in the car mags in the newsagent to find one.
    Or maybe a Harley shop, not a newbike dealer but one that does custom
    and vintage bikes. They will probably know someone who can rebuild it.
    Zebee
    Zebee Johnstone, Sep 8, 2004
  3. david
    atec Guest
    find a reputable brake place . seal is seals..
    I used the same place for stuff for the Jag and front caliper seals on
    the k100 , the non BMW stuff was massively cheaper .
    atec, Sep 9, 2004
  4. david
    FuTAnT Guest
    You should be able to get a mechanic around somewhere to rebuild it, but it
    would take a certain amount of time. Remember the seals for these things are
    super expensive usually. I find the price of caliper pot seals etc for front
    brakes to be utterly amazing! Ask them the price of all the seals, and then
    see if you can either do it yourself with a manual, a set of circlip pliers
    and some fiddling about, or take it somewhere to be repaired. If the
    internal mechanism is working, say the bore of the master cylinder is
    rooted, then yes, you'd want to replace it anyway.
    Cam
    FuTAnT, Sep 9, 2004
  5. david
    FuTAnT Guest
    Shit that sounds awright tim. So did that change the ratio then as well, by
    putting in a bigger master cylinder? How did it work after the rebuild?
    Sounds like a goer.
    Anyhoo, how's the moto?
    Cam
    FuTAnT, Sep 9, 2004
  6. david
    david Guest
    Thanks Zeebee, Tim & atec.
    I will visit a local brake specialist and see what they can do.
    Ta
    David
    david, Sep 9, 2004
  7. david
    glitch1 Guest
    Bring the whole assembly to a good brake-place (NOT the chain-shops).
    Ask for it to be honed and re-sleeved with a stainless steel sleeve to OEM
    dimensions, buy the OEM repair-kit from BMW (spring/seals/other small
    parts), reassemble (use brake fluid to lube all the parts while doing it).
    Should be around the $130 mark total, better than new (due to the SS
    sleeve), never given any trouble on cars/bikes/ caravan here.
    cheers
    pete
    glitch1, Sep 9, 2004
  8. david
    david Guest
    Thanks Pete,
    I checked with BMW parts, and the "rebuild kit" consisting of seals,
    springs & piston costs $108.
    I plan to call into a local brake shop and sound them out.
    Ta
    David
    david, Sep 9, 2004
  9. fulliautomatix, Sep 9, 2004
