Tank and tap cleaning
Discussion in 'Classic Motorcycles' started by Gyp, Jun 16, 2009.
  1. Gyp
    Gyp Guest
    The tank on the R65 is full of crap. I don't think the tank itself is
    rotten, just the filler cap which seems to have turned to rust.
    What's the best way to flush it out?
    And anyone know if BMW fuel taps are dismantleable/ rebuildable or
    should i just buy another one (as that's so full of crap I merely get a
    dribble out of it)?
    Gyp, Jun 16, 2009
  2. Gyp
    Gyp Guest
    Just read the FAQ.
    Panda Cola
    Gyp, Jun 16, 2009
  3. Gyp
    Pete Fisher Guest
    Probably OK in many cases, but it wasn't up to de-gunging the old Puch
    Gran Prix moped tank resurrected for the Forgotten Error. TBF that had
    been sitting nearly empty in an old leaky greenhouse[1] for 10 years.
    Had to go the full POR15 refurbishment route (marine-clean etc.). Very
    satisfied with the reults though.
    [1] Which is at long last 'down' - well the glass and timber bit. To my
    astonishment I had 5 freecyclers after the panes of glass that were
    still usable and the local Civic Amenities site accepted what wasn't.
    They told me to put it in the burnable container which seemed odd, but
    presumably it just ends up in the incinerator ash.
    | Pete Fisher at Home: |
    Pete Fisher, Jun 16, 2009
  4. Gyp
    Gyp Guest
    Did you use "diet"?
    Gyp, Jun 16, 2009
  5. Gyp
    Pete Fisher Guest
    Ha. No, just the cheapest nastiest cola I could buy, but not so much
    sugar but loads of phosphoric acid ought to work better in theory.
  6. Gyp
    I noticed you found the FAQ'd method but check first if it's the tank's
    internal coating that is flaking off. I've had this on at least one
    airhead and it's a pain in the backside and might be mistaken for rust
    because the coating has a 'rusty' colour to it. If it's the coating
    you're looking at some sort of mechanical removal of the flaky bits as
    the brown fizzy drink won't really help with that.
    I think they are rebuildable.
    Timo Geusch, Jun 17, 2009
  7. <AOL>
    It's a red lead coating, IIRC.
    The Older Gentleman, Jun 17, 2009
  8. If you have a cement mixer....
  9. Gyp
    A.Clews Guest
    Thus spake The Older Gentleman () unto the assembled multitudes:
    They can be rented from plant-hire firms, though might work out pretty
    expensive for just a day.
    A.Clews, Jun 17, 2009
  10. Gyp
    Simon Wilson Guest
    Doesn't everyone? It's on my list of must-haves.
    Simon Wilson, Jun 17, 2009
  11. Gyp
    Guest Guest
    It's certainly red paint, and a PITA.
    I'm going the POR15 route with mine, as I'm fed up with petrol all over
    my boots, etc. The taps have rather coarse gauze filters up inside the
    tank, meaning big enough pieces get through to stop the float valves
    closing.
    There was discussion on this recently. If you've got red bits in the
    float bowls, you've got the same problem.
    By the way, IIRC, one of the taps, I think the RH one, is LH thread onto
    the tank (R80RT '86). Go carefully.
    Sherlocks have these parts listed:
    Petrol Taps
    Complete Taps
    109557 Vertical feed, complete, Karcoma 23.00
    109113 Horizontal feed, complete, c/w filter, LHS 19.55
    109114 Horizontal feed, complete, c/w filter, RHS 19.55
    Parts
    109085 Petrol tap rebuild kit, Karcoma 6.32
    109368 Internal filter, Karcoma, within tap itself 1.96
    109516 Internal filter, Germa, within tap itself 2.30
    109518 Germa tap cap, with on / off written 1.96
    109367 Karcoma tap cap, with on / off written 1.96
    109110 Filter, in petrol tank, shrouds pipes 3.45
    109061 Tap to tank washer 0.28
    109366 Petrol pipe connector, grey plastic at tap 1.47
    I don't know what's in the 'rebuild kit' -- give 'em a ring?
    Guest, Jun 17, 2009
  12. Gyp
    Gyp Guest
    It's not tank lining. I'm going to break out the panda cola this weekend.
    Unless the cola will mess up the tank lining that is...
    Which is good. I think blowing the crap out should do it though.
    Gyp, Jun 17, 2009
  13. Gyp
    Guest Guest
    Hmm, thinks: The R80 is marginal at speed with both taps and a full
    tank, i.e. one tap per 400cc (ish). One tap for 650cc sounds not good to
    me. Having had to do a head rebuild after a carb diaphragm failed and
    the mixture on one pot went lean, I'd want a really good fuel flow.
    I suppose it could be a different, bigger, tap. The Clymer manual lists
    (and has diagrams for) four different types. The first one looks like it
    might have better flow.
    Guest, Jun 17, 2009
  14. Gyp
    Gyp Guest
    Don't be daft.
    Unless it's blocked, each tap will flow way more than the needs of the
    engine.
    There's 2 on some bikes for convenience/range, that's all.
    Gyp, Jun 18, 2009
  15. Gyp
    Guest Guest
    Well if you run this R80 on one tap, it noticeably affects the engine.
    Could be crud in the tank, it's true, but the route through the tap
    isn't very wide (I've had them apart in the past). If the area was that
    of the pipe, or even the pipe spigots, it would be fine, but inside the
    tap I don't think it's close to that.
    Not in this case, although obviously it lets you get all the fuel when
    the level goes below the saddle.
    The Airheads list covered this extensively in the past, also the pros
    and cons of fitting in-line filters.
    Guest, Jun 18, 2009
  16. Actually, not necessarily. Some bikes really do need the double flow -
    Morinis, for one, and my old airhead boxer needed both taps open if you
    were really going for it.
    The Older Gentleman, Jun 18, 2009
  17. Gyp
    Gyp Guest
    I do, it doesn't.
    YAMV [1]
    [1] Your Airhead May Vary
    Gyp, Jun 18, 2009
  18. Gyp
    Pete Fisher Guest
    In communiqué <1j1i0mb.16eqik11jycsneN%>,
    Eh? The original Morini 350 had an electronic main tap with a separate
    manual reserve. I never noticed any issues with mine.
    TBF though, I always opened both taps on the 250/375 (each having a
    reserve position).
    The Forgotten Error seems happy with just one, but then it doesn't spend
    long on full throttle.
    Pete Fisher, Jun 18, 2009
  19. Gyp
    Gyp rides very slowly, so his fuelling requirements are slight.
    platypus, Jun 18, 2009
  20. Gyp
    Guest Guest
    Thank you!
    Guest, Jun 18, 2009
