Tank Cleaning.
Discussion in 'Australian Motorcycles' started by Black Bart, Feb 4, 2004.
  1. Black Bart
    Mike.S Guest
    w/v = weight volume i think.
    methylated spirits is the go.
    Mike.S
    Mike.S, Feb 5, 2004
  2. Black Bart
    GB Guest
    And ducks, don't forget the ducks.
    G
    GB, Feb 5, 2004
  3. Black Bart
    Black Bart Guest
    Left it in the sun all day yesterday with the filler cap open and it's
    now completely dry. Listening carefully. I can't hear anything sloshing
    inside the tank.
    Black Bart, Feb 5, 2004
  4. Black Bart
    GB Guest
    That's a trap for young players that is. The water isn't
    gone, it's just dehydrated. You go putting petrol in
    that tank now, and the water will re-hydrate again and
    clog up the carbies and lines just as before.
    G
    GB, Feb 5, 2004
  5. No wonder that shit's bad for me!
    Pisshead Pete, Feb 5, 2004
  6. And rehydrated water will stop it wheelstanding too...
    Cheers
    (Just trying to help)
    Kevin Gleeson
    Technical Director
    Blue Rocket Productions
    Hobart, Tasmania, Australia
    www.blue-rocket.com.au
    Kevin Gleeson, Feb 5, 2004
  7. Black Bart
    sirprice Guest
    Dunno about the classic GPZ 900 but on my old Z750 you have to
    pull the clutch in the enable the starter to work so maybe the
    prob is in that area .
    Dave P
    sirprice, Feb 6, 2004
  8. Black Bart
    Black Bart Guest
    That's what the litre bottle of metho I have is for. The remaining vapour.
    It's going in first and getting throughly sloshed about the whole tank
    to take up any water and then the tank will be fully filled with fresh fuel.
    The amount of water that was in the tank couldn't all be vapour,
    some or most of it had to escape out the top of the tank with the hot
    air as it rose to the top.
    When I checked the tank it was at 11 at night and it was cool.
    That much water vapour should have recondensed back to liquid
    once the tank cooled down. It was clearly audible when tilting the tank.
    There would have been close to a litre at least in there. When I checked it,
    I couldn't hear a thing even with my ear to the tank. So there's either a small
    cloud floating in the tank or most of it actually dried out.
    Black Bart, Feb 6, 2004
  9. Black Bart
    Moike Guest
    Way to go, GB.
    Who would have thought you would catch anything at all with that tatty
    bit of bait. Novel, though.
    Moike
    Moike, Feb 6, 2004
  10. Black Bart
    X-No-archive: yes
    GB wrote;
    I bought some dehydrated water .... but I can't figure out what to add.
    Steven Wright
    Knobdoodle, Feb 6, 2004
  11. Seen it on a Roadrunner cartoon once, so it must be true. Acme dehydrated
    water, just add water.
    Alan Pennykid, Feb 6, 2004
  12. Black Bart
    GB Guest
    Works it's way down to the shaft, and then it's
    pretty much all over.
    And don't you think for a moment that I don't
    appreciate it my friend!
    G
    GB, Feb 6, 2004
  13. Black Bart
    GB Guest
    Hey! I'm as surprised as you are! Pretty bloody
    pleased with myself tho!
    G
    GB, Feb 6, 2004
  14. Black Bart
    GB Guest
    Read somewhere (on "teh intarweb", so it must be true)
    (actually in column 8 I think) that there's a mob here
    in sydney that sells dehydrated mineral water, no kidding.
    Apparently half of these pricks flogging 'mineral water'
    just buy this powder of a bunch of good minerals and
    mix it with filtered tap water.
    Can't say I'm surprised. No bloody way someone doing
    the quantities that Coca Cola (aka 'Franklin') do is
    getting the water out of a hole in the ground up
    bush somewhere.
    G
    GB, Feb 6, 2004
  15. Black Bart
    conehead Guest
    Oh. Right.
    I read somewhere that tampons on a stick are good for getting the last bit
    of moisture out.
    conehead, Feb 6, 2004
  16. Black Bart
    conehead Guest
    Just add anti-silica gel!
  17. Black Bart
    Doug Cox Guest
    As a matter of interest, one of their filling points around here was a
    fairly ordinary pipe attached to a suburban school fence that was fed from
    an underground stream, the original above-ground path of which can still be
    followed through the suburbs today...
    Doug Cox.
    Work to ride, Ride to work...
    Doug Cox, Feb 6, 2004
  18. Black Bart
    Goaty Guest
    Been up Mt Franklin lately? Only water for miles is in a primary
    treatment settling pond. Always though that stuff was a load of ...
    Cheers
    Goaty
    Goaty, Feb 6, 2004
  19. Black Bart
    Mike.S Guest
    "heeeeeere fishy fishy fishy"
    Mike.S
    Mike.S, Feb 6, 2004
  20. .....w/v = weight/volume
    Hammo
    Headache due to impact of vehicles and not beer.....for once. I guess I
    really do need a sidecar now.....What'll fit a z13 or a CX6.5?
    Hamish Alker-Jones, Feb 7, 2004
