tank protector removal
Discussion in 'UK Motorcycles' started by Pip Luscher, Oct 21, 2009.
  1. Pip Luscher
    ....am I right in thinking that one needs hot air? and if so, how hot:
    is a hairdryer up to it?
    The fuel tank is plastic, btw ., so it can't get too warm.
  2. Orc welder ;-)
    The Older Gentleman, Oct 21, 2009
  3. Pip Luscher
    Dave Emerson Guest
    Yes it should be, especially with a good soak of WD$4 beforehand and a
    length of dental floss to pull thru the glueline.
    PS. Make sure the h'dryer doesn't draw petrol fumes, otherwise you could be
    left just holding the protector....
    Dave Emerson, Oct 22, 2009
  4. Pip Luscher
    this sounds wrong, but make sure the tank is full of petrol as it will act
    as a heat sink and help even the heating and protect against local heat
    spots
    wessie, Oct 22, 2009
  5. Pip Luscher
    Beav Guest
    Warm, not HOT. A hairdryer is perfect. Work a small bit at a time and just
    "waft" the dryer all over, don't concentrte on one spot.
    Thank **** coz it'll weld the sticker even tighter if you do.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 22, 2009
  6. Pip Luscher
    Ooh, clever.
    Um. I wonder whether my shed fire extinguisher is up to it....
    Pip Luscher, Oct 23, 2009
  7. Pip Luscher
    Well, I idly just tried lifting a corner and it came up easily, so I
    pulled further and the whole thing just peeled straight off without
    heat. Pity the other jobs haven't gone as easily.
    Pip Luscher, Oct 24, 2009
  8. Pip Luscher
    Beav Guest
    Add some heat to the other jobs :)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 25, 2009
  9. Pip Luscher
    Heh. I have. Among the *many* stuck fasteners (this was one seriously
    neglected bike), the LH exhaust clamp screw snapped when I tried to
    undo it. It's the only place I've been able to use the blue wrench so
    far; everything else has been fastening something delicate.
    Pip Luscher, Oct 25, 2009
  10. Pip Luscher
    Beav Guest
    What you need is a stud extractor set.
    http://cgi.ebay.co.uk/Laser-4462-St...tZUK_Hand_Tools_Equipment?hash=item3a53b29770
    Summat like that. Snap-on and Blue-Point do their version albeit a tad more
    expensive, but as you're not de-studding every day, I reckon these are worth
    a punt.
    Beav
    VN 750
    Zed 1000
    OMF# 19.
    Beav, Oct 25, 2009
  11. Pip Luscher
    Actually, I probably could use one, but most of the screws I've had to
    undo would have been impossible to use the set on.
    Some were bloody awkward rather than needing extra tools, like the
    rubber instrument mount that was broken, leaving just a disc with a
    threaded stud that passed through a mounting plate: turning the nut on
    the stud simply turned the disc.
    Ditto the thee button-head screws on the instruments: they turn but
    don't unscrew. Those ones aren't urgent so I've left them for now.
    The two bolts I had to drill passed through the plastic rear mudguard;
    these were recessed button-headed Allen bolts.
    All the others (apart from the exhaust one) came apart with Plus-Gas
    and lots of working back and forth, a fraction of a turn further each
    time.
  12. Pip Luscher
    Beav Guest
    Oh the sheer joy:)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 26, 2009
