Tappet Trouble
Discussion in 'Classic Motorcycles' started by sweller, Jul 17, 2007.
  1. sweller
    Ongoing battle with the Guzzi's tappets.
    The L/H exh tappet was noisy and having worked out I'd not done them for
    over a year thought it might be a good idea.
    The Guzzi tappets are simple screw and locknut and all were within
    tolerance except the L/H exh which felt very 'gritty' when I was winding
    it out. Removing it I found a few turns of the thread damaged as well as
    the nut.
    Imagine my surprise when I discovered the M8 1.0 threaded locknut was
    over £5 from Guzzi and the tappet adjuster itself was just shy of £10.
    Fortunately the fine threaded nut was only 20p from Namricks round the
    corner (it's a 13mm spanner rather than 11mm as was but the early models
    had 13mm so isn't a problem). I still had to buy a replacement adjuster.
    Problem is it goes out of adjustment very quickly (2 miles) and the
    threads in the rocker itself feel sloppy.
    Getting a replacement rocker is going to be tricky (even secondhand,
    unless JB has one?) and Friday is the only day I can work on it and I'm
    on the 06.25 ferry Saturday.
    I'm thinking of Loctite - what say the panel?
  2. sweller
    Gyp Guest
    Valve seats?
    Gyp, Jul 17, 2007
  3. sweller
    Beav Guest
    If you're eventually going to get a new rocker, use Loc-Tite's "Stud-loc"
    and it'll never move again. You WILL have to buy a new rocker and adjuster
    though or hit the parts with a gas axe to break the bond.
    Nothing ELSE but Stud-loc will go even halfway to seeing it work for a
    decent time period.
    Thread-loc CERTAINLY won't, nor will Loc-tite 240 or 242. IIRC the number is
    270 (ish) for Stud-loc
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 18, 2007
  4. sweller
    I'm unhappy to do such a bodge on stressed engine internals and the price
    of a fine pitch tap probably won't be too different to a new rocker.
    18 ft/lb is pretty much the standard torque for an M8 nut.
    sweller, Jul 18, 2007
  5. Is there room to put a second nut on, to act as a locknut?
    The Older Gentleman, Jul 18, 2007
  6. sweller
    MikeH Guest
    <south pacific mode>
    Tappet, tappet, tappet, tappet torque
    Torque about things you can't undo
    <\spm>
    MikeH, Jul 18, 2007
  7. sweller
    JB Guest
    I've got one. Email with a postal addy and I'll get it down to the post
    office today.
    jmbyrne_AT_greenyonder.co.uk (changing the colour to blue obviously)
    JB
    JB, Jul 18, 2007
  8. sweller
    I read your posts and sometimes have to really wonder what's occurring
    inside your head.
    CT, Jul 18, 2007
  9. sweller
    MikeH Guest
    *You* wonder?
    Try being on this side of it.
    MikeH, Jul 18, 2007
  10. sweller
    Greybeard Guest
    It might well be worth having a chat with a local engineering firm, or maybe
    a decent local bike-shop, about helicoiling.
    Used it myself, in fact, I bought a kit not too far back as it really does
    work. Helicoils are not happy about being unscrewed and screwed up again to
    many times though, but for tappet adjusters I'd have thought it just the
    jobby as you never really actually back the thread right out each time you
    adjust.
    JMH2PW.
    Greybeard
    FLHTCUI UK-07 Mk II
    Trumpet Trophy 1200 new one coming soon!
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Jul 18, 2007
  11. sweller
    Mark Olson Guest
    I thought the issue was time, as in you not having enough to get your
    hands on a new rocker before your Chimay trip, but I see elsewhere
    in this thread someone has popped up with a spare rocker arm just in
    the nick of time so it appears you are all sorted out.
    I would also simply replace the rocker arm... unfortunately for me,
    when the oil line to my ZG's cams got blocked, all the rockers (x8)
    plus the cams got wiped out:
    Part Number: 12016-1126
    Description: ARM-ROCKER
    Source: KAWASAKI
    Price: $47.00
    Luckily a fine fellow on the Concours forum had a spare set of cams
    and rockers for beer money. There's a lot of nice folks out there.
    The ones I was referring to are 7mm, so not too much different.
    Mark Olson, Jul 18, 2007
  12. sweller
    I know it'll be hardened steel _but_ if it's only case hardened and
    the core is reasonable soft (1) then is there enough access to fit a
    helicoil? A helicoil set will cost you next to **** all, it's an easy
    job to do and it's not going to let go 50 miles from Chimay.
    I can do you a talk through for fitting the insert over the phone in 5
    minutes so if you want to go for it then give me a bell. Champ can
    supply my number if you don't already have it.
    (1) If the threads have fallen out rather than come out as small
    chippings then it ain't hard.
    Andy Bonwick, Jul 18, 2007
  13. sweller
    Try cam followers at over £25 each (I think that's inc. VAT). I
    suddenly made an engineering decision that slightly pitted followers
    didn't matter that much.
    Pip Luscher, Jul 18, 2007
  14. sweller
    JB Guest
    And fitting a set of oversized followers is a **beeeetch**! If I _ever_ have
    to do that reaming job again I quit. The sodding jig to hold the crankcase
    aligned in the mill took me about 7 hours to build FFS.
    JB
    JB, Jul 18, 2007
  15. sweller
    Yep, I've found that I spend more time making up fixtrues than
    actually doing the bodge^h job itself.
  16. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip Luscher
    Oh yes.
    And *every time* I get tempted into a short cut, I regret it. Large.
    Honda GL1000K2 (Falling apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Suzuki TS250 "The Africa Single" Honda ST1100 wiv trailer Norton 850 Commando
    Wicked Uncle Nigel, Jul 18, 2007
  17. sweller
    JB Guest
    Indeed. Usually at my own expense too.
    JB
    JB, Jul 18, 2007
  18. Using the patented Mavis Beacon "Hunt&Peck" Technique, JB
    *Always* at mine.
    BTW, Monday might be tricky. I'll call you in the morning.
  19. sweller
    Statto Guest
    What a wonderful typo.
    Statto, Jul 18, 2007
  20. I've been whooshed here, I think.
    The Older Gentleman, Jul 19, 2007
