Tech question. Virago 535
Discussion in 'UK Motorcycles' started by Lozzo, May 25, 2008.
  1. Lozzo
    How do you cut the fuel supply to remove the fuel tank please?
    A friend has just been on the phone asking because they're trying to
    replace the battery on their daughter's one. They've pulled the tank up
    and can see a fat pipe and a thin pipe going up directly into the tank,
    but there's no visible method of cutting the fuel supply before
    removing either pipe. It has an electrically operated reserve switch on
    the right handlebar too.
    It's a 96 bike if that makes any difference.
    Cheers.
    Lozzo
    Suzuki SV650S K5
    Honda CBR600 FW trackbike
    Yamaha SR250 Spazz-Trakka
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, May 25, 2008
  2. Lozzo
    T i m Guest
    I don't think you can?
    I *think* you can change the battery with the tank pulled out of the
    way but it's been a while now.
    I think when I was doing any of that on hers [1] I siphoned the top
    tank and then did the same through the fuel gauge / sender hole on the
    bottom one?
    From memory that just shuts off the fuel pump when the level reaches
    reserve. You then switch it to reserve to re-start it again.
    All the best ..
    T i m
    [1] The second time we made sure it was empty ;-)
    T i m, May 25, 2008
  3. Lozzo
    Brilliant, I've passed that one, thanks.
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, May 25, 2008
  4. Lozzo
    T i m Guest
    NP
    FWIW (and in case they get stuck and get back to you), on the early
    bikes the tank was simply under the saddle, with a dummy in the std
    tank position.
    Later bikes had a (2G?) tank under the saddle and an extra (1G?) tank
    in the std position, coupled to the lower tank by two rubber hoses
    (one larger one for 'fill' and a smaller one for 'breathe').
    If the top tank was nearly empty and if you freed the hoses from their
    clips on the frame, I think there was just enough room / slack to part
    the hoses and pull the battery up from in-between (two person job).
    If the fuel level was down to the lower tank, one or both the hoses
    could be removed from the upper tank (spring type jubilee clips)
    allowing the hoses to be manipulated easier.
    The missus actually went from her KH125 to an early XV535 that had
    been modified with a modded_later_top_tank (std exit holes blocked up
    an a traditional tap / hose fitted) but they were treated like two
    separate tanks. ie. You would use up the lower tank then drain the top
    tank into the bottom one (like filling it from a plumbed_in Jerry can
    etc).
    I put it back to stock before selling it and getting her the later
    model (then the XV750). ;-)
    All the best ..
    T i m
    T i m, May 25, 2008
  5. Lozzo
    gazz Guest
    As others have mentioned, you cant on the upper tank, it feeds fuel to the
    lower tank through the big hose.
    I managed to get the upper tank off when it was half full a couple of times,
    i managed the pull on the hoses enough to tip the tank forwards to theres no
    fuel at the hose outlets, then undid them and passed the tank to a helper
    who held it pointing downwards, but not too far so the fuel came out the
    cap's breather... but if the bikes been ridden more than about 40 miles
    since last re-fueling, the top tank will be empty anyways, it only holds
    about 4 litres if that.
    On the early models, when the fuel ran low the fuel pump was shut off to
    simulate running out of petrol, flicking the switch allowed the pump to run
    again,
    the later models with the twin tanks, the switch operates a solenoid at the
    tap in the bottom tank, changing to reserve as you would manualy but doing
    it electricaly... but the solenoid is a known weakness on that bike,
    If it's not switched to reserve that often, then the solenoid will likely
    jam in the normal position when you need it the most, most xv535's will have
    had the solenoid unit replaced at least once it their life time... a good
    clout on the actual unit when the switch is in reserve will usually get it
    to change over when your stuck at the side of the road, but it's a bastard
    to get at in the first place, and then theres the risk of it sticking in the
    reserve position after it's switched over.
    gazz, May 26, 2008
  6. What is this upper tank of which you speak? New fangled nonsense, I'll be
    bound.
    Mungo \Two Sheds\ Toadfoot, May 26, 2008
