Termies!
Discussion in 'UK Motorcycles' started by Hog, May 29, 2008.
  1. Hog
    As Sig. Fucking hell but they sound good, I think it was 1983 since I
    had a bike that sounded quite so nice.
    The ST4 has a genius mounting system. The exhaust comes under the back
    of the engine and branches into a T with an outlet at either side at
    right angles to the bike. The silencers have a straight link pipe with
    a 90deg turn at the end. The ID is at least 50mm so there isn't any
    great impediment to gas flow. So with the silencer slipped over the
    exhaust outlet it is free to rotate in the long axis of the bike. One
    bolt then attaches the silencer to the pillion footrest hanger. It has
    two locations, one high for max ground clearance and one a little lower
    for hard luggage.
    A long spring pinches the silencers together at the exhaust downpipe
    junction making a sufficient seal.
    So to remove the standard pipes, mount the Termi's and run the bike up
    took 20 minutes, a pair of pliers and an 8mm allen key. Sheer genius.
    Hog, May 29, 2008
  2. Shirley you cannot just tease us with a mere write-up. Where are the
    photos, and is there video/audio footage?
    Sean Hamerton, May 29, 2008
  3. Hog
    SD Guest
    About the same as fitting the Promotives to the Blackbird, then.
    Just checked: 50mm ID
    SD, May 29, 2008
  4. Hog
    [snip]
    do all ducatis have a two-into-one-into-two arrangement? For some
    reason I assumed it'd be two-into-two.
    darsy, May 30, 2008
  5. Hog
    antonye Guest
    Actually, it's not a true two-into-one-into-two system as you
    think, but more of a two-into-shared-two system as per the SS
    and monsters with twin zorsts; smaller 400/600 use two-into-one.
    It uses a strange cruciform centre piece to make an attempt at
    balancing the lengths:
    http://www.moto-one.com.au/performance/pics/p888ex1.jpg
    In the above pic the front of the bike is at the bottom, and
    the left-hand picture shows a typical SS/Monster/851/888
    header set with the cruciform in the middle.
    But ideally what you really want is the "spaghetti" headers that
    have true equal lengths, but cost a fortune:
    http://www.mikiel.net/Ducati/Images/B-N_spaghetti_header.jpg
    antonye, May 30, 2008
  6. Hog
    zymurgy Guest
    Pliers ? Bloody phillistine.
    There's special tools now for exhaust springs ...
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230251719952
    Paul.
    zymurgy, May 30, 2008
  7. Hog
    antonye Guest
    <snip>
    Damn, pressed Send too early...
    The 916 line has a true 2-into-2 system all the way to the
    end cans, but Ducati changed this on the 999 line to have
    a two-into-(short)one-into-twin-cans, possibly to save
    space given the conventional double-sided swingarm. I'm
    not sure about the 1098 line, but from pics it looks like
    they've kept the 999 setup. It's interesting to note that
    the "performance" systems have as short possible sections
    of single pipe, presumably to improve/increase flow.
    My Hypermotard uses a similar two-into-one-into-twin-cans
    system but the performance upgrade is a two-into-one; but
    that looks much more trick. Same with the Uglystrada.
    The new 696 Monster has a re-routed system (up and over
    the crank case instead of the traditional under-and-foul
    -the-oil-filter route) but still has a small section of
    single before going back to twin cans.
    I expect it's probably a cost exercise as the catalytic
    converter resides in this single section of pipe on all
    the bikes with two-one-two systems.
  8. Hog
    Krusty, May 30, 2008
  9. Hog
    antonye Guest
    Heh. Just make your own by cutting off all but the last
    turn of a traditional bottle opener!
  10. Hog
    zymurgy Guest
    Damn, what a good idea.
    Oh well, I've had mine for a while, I use it on brake shoe springs.
    P.
  11. Hog
    Eddie Guest
    I've got a very old and large penknife, which has a "hook" blade which
    is ideal for such purposes. Dunno what it's intended purpose is meant to
    be, though.
    Mind, it's also got a "thing for getting stones out of horses' hooves",
    and I've no idea if that's really what that blade's meant for, either.
    Eddie, May 30, 2008
  12. Hog
    It's for carrying parcels tied up with string, or heavy carrier bags
    with thin handles.
    Fish hook remover?
    _______
    Ace, May 30, 2008
  13. Hog
    ta.
    darsy, May 30, 2008
  14. Hog
    Eddie Guest
    I suppose it could be. Mind, carrier bags as we know them weren't around
    when this knife was made.
    Nah, *way* bigger than that. Long, thin, square-section, 90deg curve at
    the end into something like a screwdriver blade.
    Eddie, May 30, 2008
  15. Hog
    cheese knife?
    darsy, May 30, 2008
  16. Hog
    Eddie Guest
    "Long, thin, square-section"? It's maybe 4mm square, from memory.
    And it hasn't got a cutting edge.
    Eddie, May 30, 2008
  17. Hog
    Removing Boy Scouts from horses' hooves.
    Pip, May 31, 2008
  18. Hog
    Eddie Guest
    If anybody still cares, it looks like this:
    http://homepages.gotadsl.co.uk/~deguello/ukrm/DSCF0364.JPG
    The blade I'm talking about is at 8 o'clock. Note that it isn't sprung
    like a normal blade, it's kept "closed" by the hook clipping round the
    end of the body, and open by resting your thumb on the wider section
    near the pivot.
    Previously mentioned "hook" blade is at 2 o'clock, obviously.
    Eddie, Jun 1, 2008
  19. Hog
    platypus, Jun 1, 2008
  20. Hog
    Eddie Guest
    Eddie, Jun 1, 2008
Similar Threads
Loading...
