Textile/cordura repairs
Discussion in 'UK Motorcycles' started by Kiran, Mar 3, 2005.
  1. Kiran
    Kiran Guest
    On topic for once.
    I've burnt through [1] a small bit of my Hein Gericke Voyager goretex
    trousers. The gore tex shell is intact, and it's just the outer that
    has roughly a one inch hole.
    Can this be repaired - if so, any recommendations?
    Ta
    [1] touched against a hot exhaust/downpipe for a few miles before i
    realised.
    Kiran (via google)
    Kiran, Mar 3, 2005
  2. Kiran
    Buy another pair, you pikey ****.
    CT, Mar 3, 2005
  3. Gaffer tape or a bit of rubber inner tube.
    Whinging Courier, Mar 3, 2005
  4. Kiran wrote
    Don't worry about it dude. I did the same thing to the lower inside leg
    of mine on My Baby's CG two years back. It left a hole the size of a
    50p and a circle of charred to buggery around it but it simply hasn't
    been an issue.
    steve auvache, Mar 3, 2005
  5. Kiran
    you can get self-adhesive fabric; you can /possibly/ get vaguely
    waterproof self-adhesive fabric.
    darsy, Mar 3, 2005
  6. Kiran
    Kiran Guest
    Yeah, the iron on stuff right? The only problem is that I'll probably end
    up ironing the pieve of fabric to the inner goretex lining. It doesn't
    really have to be waterproof to be honest - its on the back of the calf
    area, so won't get that wet. Or maybe I'll just leave it - its been like
    this for ages.
    Kiran, Mar 3, 2005
  7. Kiran
    Preston Kemp Guest
    Try a camping shop. You can get repair patches & glue for fixing holes
    in tents etc.
    Preston Kemp, Mar 3, 2005
  8. Kiran
    How big do you think Kiran's trizers are, ffs?
    Pip, Mar 3, 2005
  9. Kiran
    I'd do it anyway, for no other reason than to stop the current hole
    snagging on something and ripping itself bigger. What I'd do to avoid
    ironing the outside to the inside, is cut a but about twice as big as
    you need, then mask off the middle of it with non-sticky fabric, then
    iron it on.
    darsy, Mar 4, 2005
  10. Kiran
    Bob Mc Guest
    You miss-spelt butt.
    Bob Mc, Mar 4, 2005
  11. Kiran
    How about cutting a piece to the same shape as the hole but 10mm
    bigger all round - then slipping it in through the hole (iron-sticky
    face *outward*), flattening it out and ensuring overlap all round -
    then iron on the larger patch from outside? No accidental stickings
    that way and a reinforced repair to boot.
    Pip, Mar 4, 2005
  12. Kiran
    Kiran Guest
    Yes, good idea.
    I'll try that and see how it goes.
    Kiran (via google)
    Kiran, Mar 4, 2005
  13. Kiran
    Wik Guest
    Heh, since you did that (feet back on the pillion pegs of a Blackbird on
    a French motorway, IIRC), I've managed to do much the same to my HG
    Voyagers, too.
    Better still, I did it whilst "posing" outside HG in Slough.
    Haven't fixed it yet, either and equally doesn't seem to be a problem
    'cept I occasionally catch the hole on the footpeg, like...
    | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Mar 26, 2005
  14. Kiran
    Kiran Guest
    Posing outside HG...that's bad. But in Slough.....argh
    The only reason I wanted to repair the hols cos I was worried about catching
    it and making it bigger. I saw some "stick on" tent repair waterproof stuff
    in Blacks - but it comes in every colour except black. Then my mum dug out
    some normal iron on stuff - it went on fine, but the stick isn't very good
    so she sewed it in place. The repair is ok and should stop it catching and
    ripping.
    Kiran, Mar 26, 2005
  15. Kiran
    Kiran says...
    My mum used to give me things like that to sew up for her.
    Lozzo, Mar 26, 2005
