Thanks Champ.
Discussion in 'UK Motorcycles' started by Lozzo, Aug 8, 2004.
  1. Lozzo
    The suspension advice worked well. Bike now stops progressively when
    hard on the brakes with no swinging about from the rear. It's also
    easier to flick through S bends and the front isn't as flappy on hard
    acceleration. I didn't have to adjust very much either, I just did
    little adjustments and then rode back down the same road at the same
    speed and compared it to what it felt like previously. Half an hour and
    it was sorted.
    Lozzo, Aug 8, 2004
  2. Lozzo
    Champ says...
    I went one ring up on the front preload, one notch up on rear preload, I
    backed the rear rebound off by 4 clicks but left the rear compression
    alone. I then went up 3 clicks on front compression and went to max
    rebound on the front. I know the front rebound seems extreme, but I was
    still getting a bit of flightiness from the front while putting power
    down while still banked over and when accelerating hard over undulating
    surfaces. I tried the compression damping but that made it worse when I
    went up or down, so I started on the rebound and found that improved it.
    So I just added more clicks til it went away. All these adjustments were
    done one thig at a time and over a mile or so's testing on a swoopy
    road. After that I went for a 30 mile hoon over the back roads and was
    pleased with the result. Everything about the handling feels better now.
    I'm fairly sure, now I've had time to think about it, that the front
    flightiness was caused by the rear squatting too quickly, so I may back
    off the front rebound and start adjusting the rear compression up to see
    if that makes any difference. My only worry then is that the rear won't
    squat much at all and give the tyre a hard time causing it to possibly
    lose grip. It's a suck it and see job. I'm told that when the 207RRs do
    eventually lose grip, they do so in spectacular style and if they let
    go, then they've gone for ever.
    Lozzo, Aug 8, 2004
  3. Lozzo
    Andy Bonwick says...
    Thanks for that.
    Lozzo, Aug 9, 2004
  4. Lozzo
    'Hog Guest
    I've been going around in circles today trying to decide what tyres to put
    on the Gixxer this week.
    F-Rennsport RS1 / R-RS2
    Diablo Corsa
    BT012SS
    Pilot Race S2
    D207RR
    D208GP
    Azaro Pro.......
    **** I just don't know. Trackday tyre that is excellent in the wet and warms
    up fast for road. Bit of a contradiction in terms.
    The 207RR probably cuts the mustard on wet/dry road but overheat on track,
    know nothing about the D208. I know the 012SS and Rennsport are the dogs for
    Road Racing but no idea about wet performance of the Bridgestone.
    Multiple sets of wheels is the only right option probly.
    'Hog, Aug 9, 2004
  5. Lozzo
    mups Guest
    'Hog says...
    I've got BT012SS's on the CBR and they're fine in the wet. I'm not wet
    weather[1] riding god mind.
    [1] Or dry weather even.
    mups, Aug 9, 2004
  6. Lozzo
    'Hog Guest
    Thanks Guys. Oh it was all so much easier with Bear around.
    'Hog, Aug 10, 2004
  7. Lozzo
    'Hog Guest
    Just came back from "Harry's Tyres" in Belfast who knows his apples and he
    convinced me 2 sets of wheels are the only answer. The info on compound
    materials in track biased tyres like the RS1/2 sold me. For road he has sold
    a pair of Bridgestone's new BT014, a supposedly improved and softer 010. It
    looks nice anyway, particularly the front, just need to get some purple
    engine bolts now....
    He reckons that continuing to use my 010's on the track after they blued
    from edge to edge (F&R) would have resulted in my particular downfall. It
    marks a compound change brought on from overheating (apparently), a function
    of abuse and pressure choice. I was running 32psi IIRC.
    'Hog, Aug 11, 2004
  8. Lozzo
    'Hog says...
    Is this right. I used to blue the 020s on the 2 previous ZZR11s quite
    frequently and never had a slide that wasn't caused by underinflated
    tyres.
    Lozzo, Aug 11, 2004
  9. Lozzo
    'Hog Guest
    Hmm I dunno but it seems obvious that some chemical change has happened to
    the rubber.
    They were a bit blued on the previous set an hour before and appeared to be
    gripping pretty well before letting go. Wouldn't mind an absolute answer to
    this myself. It's easy for a tyre store to say "always change them".
    'Hog, Aug 11, 2004
  10. Lozzo
    muddycat Guest
    Suzuki recommend 33/36 for my SV650. I run it 31/34, this is with BT
    010s.
    muddycat, Aug 12, 2004
  11. Lozzo
    Why would you want them lower than recommended?
    Ace, Aug 12, 2004
  12. Lozzo
    mups Guest
    Dr Ivan D. Reid says...
    IIRC 36/42 is the standard pressure for 010's on the road but Hog was
    referring to tyre pressures on the track which is a whole different
    kettle of mixed metaphors.
    mups, Aug 12, 2004
  13. Lozzo
    Porl Guest
    Last two track days I've done the "tyre guy" took mine to around 30/32.
    Porl, Aug 12, 2004
  14. Lozzo
    'Hog Guest
    Yeah I was following the advice of the RR fraternity. I may have already
    fucked the tyre carcass running it at road pressure on the track.
    'Hog, Aug 12, 2004
  15. Lozzo
    muddycat Guest
    My mechanic[1] recommended the lower pressures. They also run a track
    school and have some experience in tires/pressure.
    [1] Hare Racing <www.hareracing.com>
  16. Lozzo
    But just for track use, yes? You seemed to imply you kept them at the
    lower pressure full time.
    Ace, Aug 12, 2004
  17. Lozzo
    muddycat Guest
    Well, no. I run them low all the time. I see no abnormal tire wear and
    it sticks like glue to the road.
