That annoying tank gun game
Discussion in 'UK Motorcycles' started by The Older Gentleman, Jan 11, 2008.
  1. Level 15 completed, 169900 points.
    Right, now I can get a life.
    (Introduced it to work yesterday: productivity ceased)
  2. The Older Gentleman
    Oh? What tank gun game?
    Tanks in advance etc.
    Pip Luscher, Jan 11, 2008
  3. The Older Gentleman
    SD Guest
    vis the Xmas tree lights one: sent it to a few colleagues in the
    office.
    When one bloke was at lunch, an enterprising soul completed it in 243
    seconds, took a screenshot, used "paint" to remove the "2" and left a
    print on his neighbour's desk.
    Said luncheon partaker then stayed until eight-thirty in the evening
    trying to beat 43 seconds, missing the whole afternoon in the pub that
    everyone else was enjoying.
    I can be a right little tinker at times.
    SD, Jan 12, 2008
  4. The Older Gentleman, Jan 12, 2008
  5. The Older Gentleman
    Doki Guest
    I preferred the version with the Gorillas.
    Doki, Jan 12, 2008
  6. Never mind - you provided entertainment for countless thousands of
    people for several hours and contributed to the decline of Britain as a
    Global Power as output tumbled.
    Howitzers rock.
    GS850x2 XS650 SE6a
    "A scone and tea at half past three
    Makes the day a little brighter
    Keep your cakes and fancy tarts
    And stick them up your shiter."
    Grimly Curmudgeon, Jan 12, 2008
  7. The Older Gentleman
    Cane Guest
    Cane, Jan 12, 2008
  8. The Older Gentleman, Jan 12, 2008
  9. The Older Gentleman
    Ofnuts Guest
    Not bad, but Gravity Pods(*) is much worse IMHO
    (*) http://wickedpissahgames.com/?page_id=3
    Ofnuts, Jan 12, 2008
  10. The Older Gentleman
    Frank Leake Guest
    Frank Leake, Jan 12, 2008
  11. The Older Gentleman
    Pip Luscher, Jan 12, 2008
  12. The Older Gentleman
    Ofnuts Guest
    Told you so :)
  13. The Older Gentleman
    Cane Guest
    Cane, Jan 13, 2008
  14. The Older Gentleman
    Cane Guest
    65000
    Cane, Jan 13, 2008
  15. The Older Gentleman
    Cane Guest
    Cover 66.6% of the game screen with white balls.
    Cane, Jan 13, 2008
  16. RTFM!
    doetnietcomputeren, Jan 13, 2008
  17. It isn't.
    Maybe you need a new mouse?
    When you're making a ball - if it touches another one of your balls,
    (ooer) that's it, finished, start making another one.
    You realise the amount of ball you can make is rationed right?
    and that you only have so many "lives"....?
  18. The Older Gentleman
    The speed the ball grows increases as the ball expands.
    That happened to me the first few attempts, then it 'clicked'. You
    have a limited number of lives and a limited number of balls you can
    create - these are shown top left, just outside the game frame.
    You're not making big enough balls (not covering sufficient area with
    each one), so each new one you make will cost you a life - then you're
    running out of lives.
    I have found A Method. I do everything by Method, see - and I've
    found one for this application.
    You position your cursor in the upper left(1) corner, and wait,
    patiently, for an opportunity - when the nasty bouncers are looking
    the other way. Then you whip your growing ball out and hold it for as
    long as you dare. Once you've released your 'click', then your grown
    ball is solid and safe, and the nasty bouncers bounce off it.
    If you slide your mouse gently to the right as you release, you will
    send your ball off down to the right, pushing the bouncers with it.
    This gives you free space for the next ball, which you need to grow
    immediately into the space vacated by the first one. Repeat again and
    again, and your balls will settle along the bottom of the frame,
    filling it.
    Before you know it, you'll have the frame half-filled and you're well
    on the way. If you get harassed by bouncers, go fill in some spaces
    between the larger balls where the bouncers can't get at you. Don't
    worry about the time, that only counts for the bonus.
    This method should get you to level 15 before you know where you are.
    I found it a rather serene experience, although I feel vaguely dirty
    having been playing with Simian's balls for an hour or so.
    1. Not the top right, because if you trap and squish a bouncer, this
    is where they come back on - right behind you.
    Pip, Jan 14, 2008
  19. The Older Gentleman
    Fascinating, innit.
    Pip, Jan 15, 2008
  20. The Older Gentleman
    I decided I ought to have a go. Thanks to The Pip Technique, I got to
    level 25 on the first go!
    It is, and I don't usually bother with these things. Cane's a right
    fucker for posting the link in the first place.
    CT, Jan 15, 2008
