That was weird.
Discussion in 'UK Motorcycles' started by Krusty, Feb 6, 2011.
  1. Krusty
    "What was?" I hear you ask. Adjusting valve clearances on a cage, that's what. Especially as they're ye olde screw & locknut types (which I'm very happy about).
    Question though - the manual says 0.2mm inlet & 0.3mm exhaust, measured hot.. Why so loose, bearing in mind they're fairly typical cold clearances on bikes?
    And why would all the inlets be tight, & all the exhausts loose? My money'son whoever did them last time getting it wrong, but I was wondering if running on LPG could make the inlets close up but not the exhausts. Seems unlikely though as they were all out the same amount.
    Krusty, Feb 6, 2011
  2. Krusty
    What did he say?
    wessie, Feb 6, 2011
  3. Krusty
    Pete Fisher Guest
    In communiqué
    I run .5 cold on the Morini (a pushrod albeit very short ones motor)
    because of the L5 cam (standard is .4), and I tend to err on the side of
    extra looseness on the exhausts as I think they may run hotter and are
    more inclined to burn. Perhaps the previous fiddler thought the same. I
    found one on my inlets a tad tight when I checked them. Not LPG, but the
    Morini was designed before leaded fuel as we discussed before.
    So, summing up, I dunno,
    | Pete Fisher at Home: |
    Pete Fisher, Feb 6, 2011
  4. Krusty
    Pressing 'O' in Agent rendered his, presumablt google-posted, text at
    least legible. The technical question is way above me, though.
    Ace, Feb 6, 2011
  5. Krusty
    <looks>
    oh, yes. Xnews has an icon to clock in the preview pane to word wrap posts
    from shitty web interfaces. In about 10 years of using Xnews I've never
    needed to look for it before.
    Anyway, just as the door was hitting your arse as you left for the piste I
    sent you an email...
    wessie, Feb 6, 2011
  6. Krusty
    To the ifrance.com address? That's long borked, so osend again to my
    work one.
    Ace, Feb 7, 2011
  7. Krusty
    Gyp Guest
    Ah, you prolly didn't get mine either... I wonder if I have the work one
    somewhere
    Gyp, Feb 7, 2011
  8. Krusty
    Hmm. Looks fine in XanaNews. Can you let me know what's wrong with it
    in Agent & Xnews so I can raise a bug?
    Krusty, Feb 7, 2011
  9. Krusty
    About the same as my car, give or take .05mm (I can't recall the exact
    figures), also measued hot. Mine's a TDi, though.
    If it's an OHV motor then the valve train is longer than a bike's
    pretty direct OHC arrangement - more room for expansion and more
    places for tolerances to play (hah!) their part.
    Also, and this is a really wild guess, if it's got an iron block and
    head then they're not going to expand as much in relation to the valve
    train itself as would an alloy engine, so the cold clearances might
    end up tighter.
    Might be different valve/seat materials. For example, FZR600s were
    notorious for closing up the inlet valves more than the exhausts,
    which was certainly my experience of them.
    Pip Luscher, Feb 7, 2011
  10. Krusty
    It's a modern (designed in 2000) alloy OHC.
    Tis possible I guess.
    Krusty, Feb 7, 2011
  11. Krusty
    Borg Guest
    Because the exhaust valve get hotter and expands more
    Borg, Feb 7, 2011
  12. Krusty
    Which is why the exhausts are meant have a 0.1 bigger gap than the
    inlets, but is irrelevant to my question.
    Krusty, Feb 7, 2011
  13. Krusty
    the OP did not word wrap in both clients
    wessie, Feb 7, 2011
