that's better
Discussion in 'UK Motorcycles' started by darsy, May 21, 2006.
  1. darsy
    some fresh petrol in the RGV, now kicks into life by the 2nd or 3rd
    kick.
    However, it'll idle for ever, but sometimes giving it a fistful of
    throttle causes the engine to die - any ideas?
    darsy, May 21, 2006
  2. darsy
    Cane Guest
    You're a fucking yuppie?
    Cane, May 21, 2006
  3. darsy
    ChrisDC Guest
    Fuel blockage?
    Was it using pre-mix? Old 2T oil can turn to jelly and block things.
    ChrisDC, May 21, 2006
  4. darsy
    It may just simply need the tits thrashing off it.
    sweller, May 21, 2006
  5. darsy
    Pete Fisher Guest
    Only sometimes - that's worse than always, at least you know then that
    something is definitely amiss.
    Two stroke = invention of the devil.
    Gassing up?
    Has it got a crankcase drain plug?
    Duff plugs?
    Top man at Loton last year just couldn't get his CR500 to run properly.
    Died when revved. Plug not clapped so far as could be told by visual
    examination. New plug - complete cure.
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, May 21, 2006
  6. darsy
    Steve Parry Guest
    It's a stroker, sometimes the plugs oil up 'cos they're not keen on being
    ridden cautiously or ticking over for long periods. Cement mixer engines
    however enjoy ticking over for ages ;)
    Steve Parry, May 21, 2006
  7. I was going to say that. Them things need to be kept hot. In fact that
    very same RGV never gave me a problem once it was hot. I think you may
    need to actually take the thing to a track and ride it.
    Paul.
    CBR1100XX SuperBlackbird
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    OMF #15
    UKRMMA #30
    Buy this house: http://personales.ya.com/wibbleypants/main.htm
    This will be ready soon:
    http://personales.ya.com/wibbleypants/bb_in_andalucia_spain.htm
    Paul Carmichael, May 21, 2006
  8. darsy
    darsy said...
    What sort of revs are you at when you give it this fistful of throttle?
    If you're way off the powerband then it won't pick up, it'll just bog
    down. It could also be that the carbs are bunged with evaporated fuel
    remnants. Easily cured by taking the carbs off, float bowls off and
    squirting some aerosol carb cleaner up the main jets, pilot jets and
    around all the other bits til the varnish looking stuff is all gone.
    Lozzo, May 21, 2006
  9. darsy
    Pete Fisher Guest
    Indeed, a good old 'dealer's decoke' may be all that is required.
  10. darsy
    I suspect this is the right answer.
    Also, as Chris says, the 2T has been sitting in the reservoir for over
    a year, probably needs replacing.
    darsy, May 22, 2006
  11. darsy
    I was going to take it for a thrash up the A10, but then it started
    raining.
    Hopefully next weekend there'll be a dry spell...
    darsy, May 22, 2006
  12. darsy
    you say "easily cured", I say "I don't know what a carb looks like".
    darsy, May 22, 2006
  13. darsy
    Fresh spark plugs probably wouldn't do any harm either.
    I think Chris was referring to petroil mixes.
    I've never known 2T to go to jelly in its reservoir - certainly haven't
    experienced it with any of the MZ ETZs I've 'rescued'. Old petroil can
    cause mayhem in carbs; tends to be of the works or doesn't type though.
    I would have thought it even less likely with fully-synth and a year
    isn't really that long for something to stand. If you do drain the tank
    don't throw it away as I can find a home for it.
    sweller, May 22, 2006
  14. darsy
    I think I'm too old to be a yuppy.
    I am thinking of buying a whale-tail early '90s 911 Turbo, in red,
    mind you. I might even make a post about it, to annoy those people who
    seem to get annoyed when I make "help me make a decision" posts ;-)
    darsy, May 22, 2006
  15. darsy
    not pre-mix - it has a seperate 2T oil reservoir under the seat
    unit[1]
    [1] that appears to require the seat unit being removed to fill it -
    top design.
    darsy, May 22, 2006
  16. darsy
    good idea - I'll get some next weekend, when I'm picking up a new
    battery for the 'blade.
    fair enough. The 2T reservoir is about 1/2 full - any recommendations
    for what to buy to fill it up? Are there any known issues with mixing
    different sorts of 2T (given that I don't know what's in it)?
    I didn't drain the tank - there was bog all in it, so I just topped it
    up with fresh petrol, and it started on the 20th kick.
    Like I said, it now starts on the 2nd or 3rd kick when it's cold, and
    on the 1st when it's hot[1].
    [1] in fact, I started it by hand when it was hot with just a shove of
    the kick-start. I realised this is probably a stupid thing to have
    done, but I'd been drinking.
    darsy, May 22, 2006
  17. darsy
    Actually, to clarify, after further investigation - it is "always when
    it's warm" and "never when it's hot", so it's not actually a problem,
    I think.
    I do agree, but it makes a nice noise[1].
    what does that mean?
    no idea.
    I'm going to get new plugs for it anyway.
    [1] I think it's actually the loudest bike I've ever owned.
    darsy, May 22, 2006
  18. darsy
    I was referring to the oil tank.
  19. darsy
    Castrol TTS or some decent Putoline stuff.
    Avoid anything with 'Comma' on the bottle.
    ogden, May 22, 2006
  20. darsy
    oh right. Well, if you answer my question about what sort of 2T to buy
    to put in it, I'll drain the old stuff and keep it for you.
    I might also look at putting a hole in the seat unit so the reservoir
    can be filled without removing the tailpiece.
    darsy, May 22, 2006
