The cat is back
Discussion in 'UK Motorcycles' started by Antony Gelberg, May 3, 2007.
  1. I had a go at starting it up, but no joy. The immobiliser light wasn't
    flashing, which didn't bode well as I can't see what power to the
    immobiliser has to do with the ignition wiring snippage.
    It's in my garage now anyway, and I'm going to let the insurance company
    deal with it, unless they try and skank me[1]. I pushed it as far as I
    could then my uncle kindly towed me up the steep hill in his P-reg, grey
    1.8 Mondeo GLX. Not a car I have ever seen the good side of before
    tonight. Definitely a weird feeling, being towed by a cage.
    I felt all warm and fuzzy wheeling it back into its rightful home.
    Something about the criminal scum not entirely getting their way. I
    know it's not regarded as the best bike in the world, but to me, it's
    perfect. I'm not good enough to make use of the extra benefits of say
    an R6, and I won't be until I start to do track days and learn how to
    ride /properly/. And even then, from what I hear, it can more than hold
    its own. Cheap to replace as well. Ashamedly, I had my eye on another
    one as I'd already given up hope on mine being found.
    [1] So, what's a fair price for repairs to damaged fairing, exhaust,
    engine casing, bent indicator and brake lever, broken ignition switch
    and hacked wiring, et al? I need to decide if I want to claim and be
    shafted over the next few years, or pay for it myself and, er, shaft
    myself now.
  2. There's £500 worth there all day long. Replacement with new parts could
    double that.
    Or: fibreglass repair kit and touch-up paint, used exhaust off Ebay,
    ignore the damaged casing, pattern brake lever and bodge the wiring.
    Cost £150.
    The ignition switch is likely to be the item where new replacement is
    the only option, unless someone does patterns. Don't know if anyone
    does.
    The Older Gentleman, May 3, 2007
  3. >,
    says...
    http://www.busters-accessories.co.uk/products.asp?id=40&pg=5
    About half way down the page
    Whinging Courier, May 3, 2007
  4. Antony Gelberg
    when my 7R was nicked and I recovered it from a ditch, I managed to
    pick up an entire lock-set on eBay (ignition, tank, seat release and
    all the connecting bits) for something like 20-25 quid.
    darsy, May 3, 2007
  5. Antony Gelberg
    Cane Guest
    .... and it now looks great.
    Cane, May 3, 2007
  6. Antony Gelberg
    I've seen worse. It really just needs a coat of Hammerite, or
    something.
    darsy, May 3, 2007
  7. Antony Gelberg
    TOG Guest
    That's the way to do it, if you can. That pattern switch WC found is
    good value, but it's nicer to have a one-key-fits-all bike.
    TOG, May 3, 2007
  8. Antony Gelberg
    <Revises target price for auction starting this evening>
    ogden, May 3, 2007
  9. Antony Gelberg
    up or down?
    darsy, May 3, 2007
  10. Antony Gelberg
    <checks spreadsheet>
    Down, by a fiver, but my original estimate was a finger in the air guess
    anyway, as there don't seem to have been any listed of late.
    ogden, May 3, 2007
  11. I'm a bit gobsmacked. They just called me and said that /from my
    description/, it sounds like a write-off. WTF?
    Ah. A look at http://www.gtsalvage.com/categories.html suggests that
    mine might finish as a Category C, as TOG alluded to above. In
    particular, "...the insurer is obliged to use new manufacturer-supplied
    parts and high-cost labour."
    They gave me the option of either having it sent to a salvage yard
    straight away, then they let me know how much I get, or having an
    engineer come and look at it here first, to advise on whether it is
    definitely a write-off, and tell me about values etc.
    WTF do I do? All I want at the end of the day is a Thundercat[1] in
    decent condition, preferably mine, without getting financially shafted.
    Maybe I should wait and see what the engineer says.
    [1] Although is this the opportunity to look for a different machine?
  12. You make them an offer for it as salvage, to be deducted from your
    payout. Ask them for a quote, offer them a lower price and see what they
    say, and remind them that your buying it off them will mean they don't
    incur any transport costs.
    Then you fix it up on the cheap, as outlined above, and pocket the
    difference.
    Or you spend a bit more time and trouble, and fix it using the best used
    parts you can find, and then ride it and pocket the difference or sell
    it and buy something better.
  13. Antony Gelberg
    darsy says...
    That's pretty much what I paid for bandit locks. I just had to buy a set
    of XV535 ones to use on the SR250 (same locks but the ignition switch
    base need modding slightly), they cost me £45.
    Lozzo
    Suzuki GSX-R750L trackbike (Shite with added shite bits)
    Yamaha SR250 Cheasy-Rider (undergoing a transformation)
    I ride way too fast to worry about cholestorol.
    Lozzo, May 3, 2007
  14. Antony Gelberg
    Macie Guest
    If Thundercats are your thing there are some shiny unregistered ones
    kicking around (although I believe they are US imports) for around
    4.5K.
    Macie, May 4, 2007
  15. Antony Gelberg
    Beav Guest
    <TOG@toil>; <>; <>
    wrote in message
    You need one of those "One-key-fits-all-bikes-keys" like the scrotes have.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 4, 2007
  16. Antony Gelberg
    Beav Guest
    First of all, the insurance co *will* only accept new parts, but as for them
    only obliged to use high-cost labour, that's utter bollocks. Get the bike to
    someone YOU want to carry out the repairs (and this could be you btw) and
    get a quote. The insco can NOT make you go to "an approved insurance
    repairer" although they always try to give that impression and I won't say
    "kick-back/commission" is there reason. If they still write the bike off,
    ask them how much they'll accept for you to buy it back, then buy it and get
    it repaired using 2nd hand/after market parts and get the thing back on the
    road with a few quid left in your pocket.
    Granted its value will takea hit once it's been written off, but it's never
    going to be worth a fortune anyway and you like the bike, so what do you
    lose? **** all.
    See above.
    Mayube you should get a quote off someone who can epiar it too. Insoc
    engineers are usually on the side of the insco's and they fucking love
    writing bikes off.
    Depends if you want to or not. I'd fight if it was my Zed anyway.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 4, 2007
  17. And you try and register them now they don't meet the new emissions
    requirements.
    The Older Gentleman, May 6, 2007
  18. Antony Gelberg
    Macie Guest
    On Sun, 6 May 2007 16:37:30 +0100,
    Does this mean they would be unregisterable then?
    Macie, May 6, 2007
  19. Yes, I think so, unless there's something in the Single Vehicle
    legislation that would work
    Remember that a lot of bikes (like the old Fazer) were pre-reg to get
    them through the deadline in June... 2005, was it?
  20. Antony Gelberg
    Adrian Guest
    The Older Gentleman () gurgled
    happily, sounding much like they were saying :
    Surely you'd just register it on an age-related plate as a <whatever year>
    bike, rather than as a new 2007 07-plate?
    Adrian, May 6, 2007
