The Dreaded Interview
Discussion in 'UK Motorcycles' started by Tosspot, Aug 15, 2006.
  1. Tosspot
    Tosspot Guest
    And I'd like to go by bike. Soooo...is it possible to go to an
    interview in a suit on a motorbike?
    The trip will be about 2 hours, possibly wet. Panniers available. Any
    tips?
  2. Tosspot wrote
    From personal experience I believe that turning up to a collar-and-tie
    interview in biker gear is generally counterproductive.
    Change into your whistle somewhere away from the interview and present
    yourself in the manner which they want to see. Dishonest I know but it
    is their prejudices that you have to pander to if you want the job.
    Bearing in mind also; you are interviewing them and you have to set this
    against whether or not you actually want to work for a management team
    that is so easily swayed in their personal opinions.
    steve auvache, Aug 15, 2006
  3. Tosspot
    BGN Guest
    Train.
    BGN, Aug 15, 2006
  4. Tosspot
    MikeH Guest
    I've done it.
    The main thing is to stick the suit & shoes in bin-bags to avoid any
    damp, and find the nearest supermarket where you could use the loo to
    change.
    Stick the leathers into the panniers & saunter across the road to the
    interview.
    Oh, good luck too.
    MikeH, Aug 15, 2006
  5. Tosspot
    steve auvache says...
    It didn't do me any harm when I rode for 3 1/2 hours on the Thunderace
    to get the job I have now.
    Lozzo, Aug 15, 2006
  6. Tosspot
    Tosspot Guest
    TBH I'd hire a car for the day if the bike thing doesn't come off,
    however, I'd prefer the bike because;
    a) It'd give me an idea of the commute time on a bike.
    b) Heh, 2 hours on a bike beats 2 hours in a car!
    I suppose I could do a dry(fnah) run and see what the issues are.
  7. Tosspot
    Tosspot Guest
    I think turning up in bike gear would be out of the question to be
    honest. Hmmm...thinks back to Aerostitches again.
    That's a great quote[1]! Was Pip really guilty of it?
    [1] And the sig sep Police can **** off. I *deliberately* pasted that in.
  8. Lozzo wrote
    You only got the job because you are cheap foreign labour.
  9. Tosspot
    Tosspot says...
    He certainly was. We were discussing my complete lack of Christian faith
    and he came out with that gem.
    Lozzo, Aug 15, 2006
  10. Tosspot
    I'm not cheap, and I vote conservative.
    Lozzo, Aug 15, 2006
  11. Lozzo wrote
    I have to confess I am considering the same but only so that I can cast
    my vote for the most left wing of the mainstream parties.
  12. Tosspot
    Cab Guest
    Don't.
    Break a leg anyway.
    Cab, Aug 15, 2006
  13. Tosspot
    Unless the interview is at 9am, you'll learn nothing useful about the
    commute time. 2 hours in a car should leave you far more presentable
    than 2 hours on a bike. Which is more important to you, getting the job
    or living the biker dream?
    ogden, Aug 15, 2006
  14. Tosspot
    dwb Guest
    And a two hour commute is going to be a pisser no matter what transport
    you use.
    So I'd say "get a job nearer home".
    dwb, Aug 15, 2006
  15. Tosspot
    Tosspot Guest
    I'll be moving closer, but on a temporary basis, iyswim. Basically
    having two abodes for a while.
  16. Tosspot
    Hankjam Guest
    What's the job.
    Have to say I've interviewed a bunch and I wouldn't say appearences
    have ever really put me off.
    As long as you know what they do and how they do it... I find that
    helps!
    Good luck!
    Aj
    Hankjam, Aug 15, 2006
  17. Tosspot
    Antonio Guest
    Like you want to have to explain a huge wet crotch on your interview. Avoid
    that option unless you have no other.
    You can ride to work as much as you like ONCE you get the job, and there's
    little they can do about it in hindsight (unless your conditions of
    employment are that you drive a car to work/ or drive a company car).
    Antonio, Aug 15, 2006
  18. Tosspot
    Would fitness be an issue here, and would he be able to make any appreciable
    difference in the time available?
    platypus, Aug 15, 2006
  19. Tosspot
    BGN Guest
    It would certainly help if he walked.
    BGN, Aug 15, 2006
  20. Tosspot
    MattG Guest
    Certainly does. I did it for the last eight months.
    Just done that.
    MattG, Aug 15, 2006
