the heart of darkness
Discussion in 'UK Motorcycles' started by darsy, Jul 3, 2005.
  1. darsy
    or, how I travelled to deepest Essex on the train, and survived.
    Actually, that was the easy (though slow) part. 2 hours for a
    40-miles-as-the-crow-flies public transport "experience".
    Where the **** is Maylandsea? I mean, I can see where it is on the map,
    but why are all the roads pointing in random directions? Essex is a
    silly place; don't go there.
    Still, Blaney's 400 Four: what a lovely bike. Excepting the front
    brake, which is a bit dire.
    Sounds lovely, looks lovely, handles surprisingly well for a mid-70s
    bike, pity about the front brake. Still, using the rear brake makes
    things OK, but it's something that is a bit of a learning curve when
    you're used to modern machinery.
    Also, leaks petrol if you leave the fuel tap switched to "on", rather
    than "of"[1]
    But still, what a nice bike; looks like a bike, sounds like a bike,
    smells like a bike etc.
    [1] yes, AFAICS it's really etched "of" rather than "off".
    darsy, Jul 3, 2005
  2. darsy
    "The force is strong in this one."
    sweller, Jul 3, 2005
  3. darsy
    I found myself earlier considering the possibility of running nothing
    but classic bikes. I think I need some sort of help.
    darsy, Jul 3, 2005
  4. darsy
  5. darsy
    darsy, Jul 3, 2005
  6. darsy
  7. They absolutely all do that, sir.
    I took mine into work the other day, and one of smokers (who congregate
    close to where I and the only other biker in ther firm park our steeds)
    ran in to tell me there was a nice puddle of fuel under the bike.
    The Older Gentleman, Jul 3, 2005
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    I trust you informed the H&S lady?
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Suzuki TS250 "The Africa Single"
    Wicked Uncle Nigel, Jul 3, 2005
  9. Damn!
  10. darsy
    deadmail Guest
    Well I doubt anything I own at the moment is 'classic' (2xK100, 1xK1100)
    but I've little or no intention of getting anything newer; as long as I
    can keep them reliable (and so far I've done >70k miles on Beemers
    without any serious break downs) I'm happy.
    New bikes don't involve me to the same degree.
    deadmail, Jul 3, 2005
  11. darsy
    deadmail Guest
    Are you the one with the strap-on though?
  12. darsy
    You should have tried it before I cleaned the caliper, replaced the
    perished pads and fitted braided hose. 'Interesting', it was.
    I'll be interested to give it a try at Chimay, because honestly, I
    didn't think it was that bad as long as you have a strong right hand.
    Or maybe I _had_ just got used to it. Or maybe it's because in my
    early years I had lots of bikes with brakes so much worse than even
    that.
    It did this once in my garage, but I never quite worked out why. Most
    of the time it was sat there (~3 years) it was fine regardless of tap
    position.
    I'm missing it already. But I am pleased it's being used - I used to
    take it out for a little blat two or three times a year, but it seemed
    such a waste somehow.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jul 4, 2005
  13. darsy
    I'm used to bikes where one finger's worth of pressure on the lever is
    enough to get the back wheel off the ground.
    darsy, Jul 4, 2005
  14. darsy
    dwb Guest
    Puff.
    dwb, Jul 4, 2005
  15. darsy
    hah! Just because you've bought a big traillie, it doesn't mean you're
    not still soft as warm shite, Dan.
    darsy, Jul 4, 2005
  16. darsy
    dwb Guest
    No argument from me whatsoever - in fact you could say warm shit after a few
    too many prunes, however, returning to motorbikes, only the GSX-R had brakes
    that worked okay'ish with one figure. Two were better.
    The Strom definitely needs 2 to work well.
    dwb, Jul 4, 2005
  17. darsy
    dwb says...
    You need some AP Racing calipers then. One finger stoppies from 100mph.
    Lozzo, Jul 4, 2005
  18. darsy
    dwb Guest
    Not sure either the suspension or the tyres would be up to that sort of
    power TBH :)
    Anyway, 100mph? As if I'd go that fast.
    dwb, Jul 4, 2005
