The innate hostility of inanimate objects
Discussion in 'UK Motorcycles' started by TMack, Mar 3, 2007.
  1. TMack
    TMack says...
    BMW
    Lozzo, Mar 4, 2007
  2. TMack
    On Sun, 4 Mar 2007 09:53:35 +0000,
    I used to make a bit of money on the side at work building up the
    heads on the originals and machining them to a more user friendly
    size.
    Andy Bonwick, Mar 4, 2007
  3. TMack
    Kim Bolton Guest
    Road crap? Road crap?
    You don't mean to say that....people....rode them....in....the rain?
    <faints>
    Kim Bolton, Mar 4, 2007
  4. TMack
    Kim Bolton Guest
    The MZ 250s that were fitted with the Mikuni oil-pump also had it
    driven from the gearbox; wise riders added 5ml of two-stroke oil to
    each litre of petrol, which had the added value of prolonging the
    life of the carburettor slide.
  5. TMack
    Kim Bolton says...
    I've never had a significantly worn carb slide on any high mileage four
    stroke, so that's a load of MZ owner's bollocks, unless they were so
    badly made they needed a constant supply of lubricant.
    Lozzo, Mar 4, 2007
  6. TMack
    Jawa Mustang with a transparent section in the nose of the fairing for the
    headlight to shine through. Headlight mounted in the traditional place on
    the front forks, turns independently of the fairing...
    platypus
    "Merely corroborative detail, intended to
    give artistic verisimilitude to an otherwise
    bald and unconvincing narrative.”
    platypus, Mar 4, 2007
  7. I'd forgotten that one. Anmd the fairing was painted in metalflake
    purple. Gotta love the 1970s.
    The Older Gentleman, Mar 4, 2007
  8. TMack
    SD Guest
    <points at GL1500>
    Take your pick.
    | ___ Salad Dodger
    |_\_____/_| ..88045../..23727.../..31893.
    SD, Mar 4, 2007
  9. TMack
    Where's Nigel's sig when you need it?
    ogden, Mar 4, 2007
  10. TMack
    Rich B Guest
    Or any feature of any bike with Jawa on the tank. But that fairing was a
    classic.
    Rich
    2001 Disco II ES auto
    1971 S2a 88" petrol
    2006 Bandit 1200S
    Take out the obvious to email me.
    Rich B, Mar 4, 2007
  11. TMack
    Kim Bolton Guest
    I take it you aren't that familiar with the quality of the materials
    that MZ were forced to work with. Besides, the carburettor slide in a
    piston-ported two-stroke sees a very different pressure-pulse profile
    than a that of a four-stroke.
  12. TMack
    Kim Bolton says...
    The old MZs I've seen and worked on have been quite impressive
    considering the limited resources they had to hand. I don't for a minute
    think that the carb slides would have worn badly if not given that extra
    dollop of 2-stroke oil.
    The materials used to make Japanese carbs are very lightweight and
    cheap, almost pitful in their nastiness, but I've never seen one that's
    got a significantly worn slide. Most Jap strokers from about 1967
    onwards had some sort of oil injection that fed forwards of the carb
    into the cases, I've never seen a badly worn slide on any of those
    either and they're subject to the same pressure-pulse profiles as MZs.
    I think the idea of putting an extra 5ml of oil per litre of fuel in the
    tank is overkill. If anything you'd be leaning off the fuel/air mixture
    a touch making it more prone to seizure unless you rejetted to suit.
    Lozzo, Mar 4, 2007
  13. TMack
    Pete Fisher Guest
    In communiqué <>, Rich B
    Even Jawa speedway bikes?
    | Pete Fisher at Home: |
    Pete Fisher, Mar 5, 2007
  14. TMack
    Pete Fisher Guest
    Perhaps it is for aromatherapy reasons.
    <fond memories of putting a teaspoon of 'R' in to the G2 tank in my
    youth for that authentic whiff of the shale[1] oval>
    [1] not cinders - I'm not *that* old.
  15. Up to and including the RG250 -- my first race at Westwood cost me
    over $600 for a new crank because I'd stalled the engine braking into the
    hairpin, and was givving it 11K-rpm beans to get moving again up the hill
    (after restarting by dumping the clutch). It seized just as I realised it
    must have been in 2nd rather than 1st...
    Dr Ivan D. Reid, Mar 5, 2007
  16. TMack
    Kim Bolton Guest
    Oh, I agree; the engineering design was good, it's just that East
    German metallurgy wasn't always up to the task. There are persistent
    rumours of front-fork clamps and clutch/brake levers fracturing in
    conditions where that would be unexpected.
    The BVF carburettor has a reputation for a high wear-rate.
    At 5 ml per 1000 I 'll take a bet that the weakening effect is less
    than one main-jet size or one notch on the needle.
    Kim Bolton, Mar 5, 2007
  17. TMack
    Rich B Guest
    OK, no - but the two-strokes were a total fucking abomination. I see
    they're using Rotax singles these days, which bodes well, but after owning
    one (a 634) I just couldn't.
    Rich
    1971 S2a 88" petrol
    2006 Bandit 1200S
    Rich B, Mar 5, 2007
  18. TMack
    Beav Guest
    Having to remove a whole engine just to get at an alternator? VN750 btw.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 6, 2007
  19. TMack
    GoldWing too.
    platypus
    platypus, Mar 6, 2007
  20. TMack
    SD Guest
    Pish-tosh.
    | ___ Salad Dodger
    SD, Mar 6, 2007
