Theory test - HAZARD PERCEPTION!!!
Discussion in 'UK Motorcycles' started by flashgorman, May 10, 2004.
  1. flashgorman
    flashgorman Guest
    You didn't see it coming then? Bad start.
  2. Hi,
    just found out about the hazard perception test, dont know much about it.
    has anyone recently taken this test. Can you give me any pointers???
    Thanks
    brendan plaine, May 10, 2004
  3. flashgorman
    Spark Guest
    Brendan,
    you will have to sit in a booth, facing a monitor. There are a load of
    different scenarios to go through. Basically, as you see hazards develop you
    will need to click with the mouse. So in the scenario you are driving along,
    someone starts to reverse out of a driveway. You will need to click on
    screen to show you appreciated the hazard. If it becomes more dangerous, you
    will need to click again. Basically, if you imagine that you are riding the
    bike, you will click for all the stuff that makes you nervous, pedistrains
    crossing, people reversing out of Drive ways that kind of thing. I was a bit
    unsure of it, but I scored 62 out of 75. Just watch the disk that the DSA
    send you, it should be fairly obvious, although to be honest, it did seem a
    bit sujective to me.
    Good luck.
    Spark RD350 YPVS FII (cloud of blue smoke)
    Vespa T5 (insert your gay joke, I'm bored)
    Spark, May 10, 2004
  4. flashgorman
    john Guest
    http://www.ourworld.rapid.co.uk/hazardp.html
    Might be a tad slow to load if your on dial up.
    John.
    john, May 10, 2004
  5. Just click the mouse when ever you think you see something that may be
    a hazard, and click it again if the hazard gets more dangerous. I
    think you can afford to be relatively generous with the 'clicks' but
    if you do too many, it will score zero.
    eg. See a pedestrian on the pavement - 'click', see a bus coming -
    'click', cyclist turns onto main road from sideroad in the distance -
    'click', pedestrian waves at bus - 'click', cyclist dissapears behind
    bus - 'click', pedestrian bolts across road for bus - 'click', cyclist
    pulls out to overtake bus - 'click'.
    You have to remember that one of the clips will have two scorable
    hazards, the other 14 have one (but you don't know which!).
    Personally, it was all relatively predicatable, and if your not too
    timid with the mouse, you should pass.
    75 out of 75 myself - well chuffed was I.
    David Thompson, May 10, 2004
  6. Just managed to dig out my copy of the DSA's DVD 'Hazard Perception -
    Roadsense', which explains the test in more detail and gives you
    practice tests.
    Free to a good home, but _only_ if you send me a stamped, addressed,
    DVD sized jiffy bag to put the bugger in.
    e-mail me for the address if interested.
    David Thompson, May 11, 2004
