There should be a special place in hell................
Discussion in 'UK Motorcycles' started by TMack, Dec 11, 2005.
  1. TMack
    TMack Guest
    There should be a special place in hell reserved for whoever it was invented
    the cotter pin ( a Mr. Cotter probably). Right alongside that one should be
    a series of additional places reserved for engineers and designers who use
    them in particularly hard-to-get-to locations. Also there should be even
    more places for the people who re-use them until they are so deformed they
    are impossible to remove without hammering and pulling with pliers - which
    is impossible because of those bastards who put them in those hard-to-get-to
    locations in the first place.
    TMack, Dec 11, 2005
  2. TMack
    So what's your solution then? You've obviously got one or you wouldn't
    be complaining.
    Andy Bonwick, Dec 11, 2005
  3. TMack
    TMack Guest
    A thread on the end of the shaft and locknut would be a better replacement
    for most of these nasty little things. A realisation that sooner or later
    someone is going to have to disamantle it for every designer/engineer and a
    nice mixed bag of different sized new pins for the people who have no choice
    but to work with them.
    TMack, Dec 11, 2005
  4. TMack
    Do you mean split pins?
  5. Are you referring to the humble split pin, perchance? Cotter pins are an
    entirely different animal.
    GS850x2 XS650
    On UKRM you're just a **** with opinions.
    Grimly Curmudgeon, Dec 11, 2005
  6. TMack
    mb Guest
    mb, Dec 11, 2005
  7. TMack
    Eiron Guest
    Eiron, Dec 11, 2005
  8. The Greatest Invention Known To Man, is your humble R clip.
    AOL. From the very first day I could wield a hammer, I knew the devilish
    device that is the cotter pin.
    GS850x2 XS650
  9. TMack
    mb Guest
    mb, Dec 11, 2005
  10. TMack
    TMack Guest
    I am referring to nasty horrible bastard split pins, also commonly referred
    to these days as cotter pins (maybe "wrongly" but language is constantly
    eveolving). I was a bit doubtful about referring to split pins as cotter
    pins. I have recently seen split pins on sale described as cotter pins
    However, I seemed vaguely to remember cotter pins being those half tapered
    bolts such as those used to keep the pedal cranks of pedal cycles in
    place(?). So to make sure, I googled for it. When I googled for "cotter
    pin" (google images) I got loads of pictures of split pins.
    e.g. http://www.engineersedge.com/cotter_pin.htm
    Even if I restrict it to uk sites I still get pictures of split pins. The
    third hit for cotter pin uk (normal google) is
    http://www.roymech.co.uk/Useful_Tables/Circlips/Split_Cotter_Pins.html
    Whilst among the hits for cotter pin uk (google images) is
    http://makeashorterlink.com/?Y5EF62B4C
    On the other hand, If I google for "split pin", the very first hit says
    "Cotter Pins - In stock" (try it).
    It looks like the term is now quite widely used for split pins.
    TMack, Dec 11, 2005
  11. TMack
    TMack Guest
    Good thinking - I will go and buy a good assortment.
    TMack, Dec 11, 2005
  12. TMack
    TMack Guest
    Concise Oxford Dictionary is about as English as it gets - NB definition 2:
    Cotter pin:
    noun
    1. a metal pin used to fasten two parts of a mechanism together.
    2. a split pin that is opened out after being passed through a hole.
    TMack, Dec 11, 2005
  13. TMack
    On Sun, 11 Dec 2005 19:01:28 -0000, "TMack"
    [cotter pins]
    Bollocks is it. Not by any engineer or motor factor I know. However,
    you refer to the term 'split cotter pin' which is probably the full
    name for the humble split pin - there arises the confusion. The Yanks
    prolly have a completely different term for yer actual cotter pin and
    therefore do not need to differentiate.
    The thing is, a cotter pin AIUI is a tapered or parallel retaining
    pin, manufactured to fit in a (frequently sliding or pivoting) joint.
    A split pin retains the cotter pin and is protected from rotational or
    shear stress by placement of a washer between it and the joint.
    Hell of a difference between a split pin and a cotter pin, therefore.
    I'd agree that a cotter pin can be an absolute twat to remove - but
    split pins are a piece of piss to a bodgineer like me, equipped as I
    am with an enormous variety of pliers, old screwdrivers, hooky things
    and bent drifts.
    A better-filled, battered toolbox is what you need. And patience,
    that's useful too. Studying the problem while having a fag helps.
    Lots.
    Pip, Dec 11, 2005
  14. TMack
    deadmail Guest
    R pin.
    deadmail, Dec 11, 2005
  15. The higgerant public at large and the rampant diy culture are
    responsible for that. Cotter pins and split pins are, and remain,
    different, and glad I am of it.
    GS850x2 XS650
  16. The good people of the Hoxford Henglish Dickshunary are not Hengineers.
    We do not need them telling us what is and isn't a Cotter Pin. We
    already know.
    GS850x2 XS650
  17. TMack
    TMack Guest
    But unfortunately it is NOW thus used by many who you are not aquainted with
    and also by the Concise Oxford dictionary . Language is evolving and not
    always in directions we like.
    SNIP!
    Which is all very well if there is any space to wield said pliers etc.
    However, the sodding thing I was working on was embeddded in rust in a
    recess that would allow almost no intrusion of tools of any kind and
    required a position that would be the envy of many yoga practitioners just
    to get at it. I eventually removed it by liberal use of plusgas and a
    masonry nail. Having managed to more or less straighten the very bent and
    contorted ends and after applying the plusgas I hammered the masonory nail
    through the eye and then levered it out at about 0.01mm a go. A worthy
    bodge in the circumstances but I have many more enjoyable half hours.
    TMack, Dec 11, 2005
  18. TMack
    Eiron Guest
    The good people of the OED didn't need telling.
    The problem is with the current tossers who think their job is to record
    and legitimize usage, no matter how inaccurate.
    Hence my old Shorter OED doesn't call a splitpin a cotter but does
    mention that a cotter is wedge shaped.
    Eiron, Dec 11, 2005
  19. TMack
    TMack Guest
    It must be quite old then - my Concise Oxford is 10 years old and has the
    above definition. I am sure that the original cotter was the wedge-shaped
    pin but language changes. For example, "sprocket" was originally a term for
    a piece of timber in a frame. I'm sure many purists objected when it was
    used to describe the toothed wheel that engages with a chain. "Gay" has an
    entirely different meaning now than it did 20 years ago. "Nice" has changed
    its meaning more than once over time i.e. stupid > fastidious > pleasant.
    You can't stand in the way of progress.....................
    TMack, Dec 11, 2005
  20. TMack
    Big Dave Guest
    Right.
    To settle it once and for all.
    According to Machinery's Handbook - Twentieth Edition :
    On Page 1141 there are dimensions for "American Standard Cotter Pins"
    which are yer basic, common or garden split pin.
    (Design Engineer)
    Big Dave, Dec 12, 2005
