Thinking about buying a cheap chookie...
Discussion in 'Australian Motorcycles' started by Toosmoky, Sep 30, 2007.
  1. Toosmoky
    Toosmoky Guest
    As the rebuild on the Trump is gunna stretch past the end of me
    holidays, I thought maybe I should buy another bike to get around on in
    the meantime and get to work on once the hols are over.
    Looking toward a big cheap chookie. Preferably around $1500. Any
    thoughts?...
  2. Toosmoky
    Biggus..... Guest
    XT/TT600.. plenty round, and pull like a 14yr old...
    Biggus....., Sep 30, 2007
  3. Toosmoky
    Toosmoky Guest
    A mate's got a KLX650 that I used for a couple of months last year but
    he wants $2500 with new tyres and 12 months rego. Could maybe knock him
    down a bit but the water-cooling puts me off.
    That'd do.
    Everyman's dream, cheap TTs...
    Not fussed about make, prefer air-cooled and simple though. Might have
    to check out the Trading Post...
  4. Toosmoky
    J5 Guest
    why ? would be better in traffic
    only a real concern if heading offroad and looking for big rocks
    as long as its tidy and the rest of the consumables are good then you cant
    really go too far wrong
    J5, Oct 1, 2007
  5. Toosmoky
    Toosmoky Guest
    Maintenance and complexity. Why have an extra system if it's not needed?
    Toosmoky, Oct 1, 2007
  6. Toosmoky
    You'll be looking for a manual spark advance, side valves and 1-speed
    gearing too, then? ;-)
    BT Humble, Oct 3, 2007
  7. Toosmoky
    Toosmoky Guest
    Had the first two with the old WLA...
    Toosmoky, Oct 3, 2007
  8. Toosmoky
    J5 Guest
    yeh putting a bit of green water in every couple of years is a headache
    J5, Oct 3, 2007
  9. Toosmoky
    Toosmoky Guest
    Not to mention hoses, radiator cores, water pumps, the possibility of
    leaks from any of those and subsequent overheating, difficulty of access
    to other components buried beneath cooling system components, etc...
  10. Toosmoky
    Toosmoky Guest
    I wish. If it were raining money I'd get hit with Yap currency.
    I've decided to go ask the Credit Union to stump me the bux for a decent
    chookie and a rebuild on the Pig. I've just spent four grand on the Pig
    and then it goes and blows the donk. Arrrghhh!
    Toosmoky, Oct 4, 2007
  11. I wonder how many other people got that without looking it up. :)
    The disdain for liquid cooling thing is perplexing, though...
    intact.kneeslider, Oct 4, 2007
  12. Toosmoky
    Boxer Guest
    A DR650 is the tool for him, it is.
    Boxer
    Boxer, Oct 4, 2007
  13. Toosmoky
    Toosmoky Guest
    I've never been much of a believer in having a car's cooling system on a
    bike. The Pig is the exception but it's an expensive little bastard to
    run. Only done half the k's the old Harley did due to the high running
    costs.
    Then there's the time I let a trusted mech do the valves. He decided the
    cooling system needed flushing too.
    I rode it 2k's home and had Mt. Vesuvius between my legs when I got
    there. Turned out some bright spark had shoved a screwdriver or similar
    down the neck of the water pump with the engine turning over. Only three
    of the eight vanes on the pump shaft were still attached but they were
    folded flat against the shaft. The other five fell out on the floor when
    I removed the pump.
    He permanently stained the frame on both sides with whatever shit he
    used, melted the top of the filler neck by using a heat gun to open the
    thermostat (obviously wasn't aware of the bleeder screw 2cm behind the
    filler) so much that I had to epoxy it and sand it flat again so that
    the radiator cap would seal.
    Recently I found that the tips of three of my fan blades have melted.
    **** water cooling.
  14. Toosmoky
    Toosmoky Guest
    Must admit it's a sweet looking bike, John.
  15. Toosmoky
    Toosmoky Guest
  16. Toosmoky
    I'm having a little difficulty seeing how all this was the bike's
    fault?
    BT Humble, Oct 5, 2007
  17. Toosmoky
    I honestly thought it was a 2-stroke!
  18. Toosmoky
    Toosmoky Guest
    It's not. I love that bike.
    Eventually though, I will have to replace components of that cooling
    system. Hoses, fan, pump, radiator, thermostat, etc. In the meantime, I
    face additional time and cost when servicing it, as to do most work the
    cooling system has to be emptied and components removed to gain access
    to other components.
    The point is that added complexity equals more potential problems. When
    I buy a second bike, I want it to be basic, simple, easy to maintain,
    cheap to maintain.
    Toosmoky, Oct 5, 2007
  19. Toosmoky
    Toosmoky Guest
    Check yer e-mail...
  20. Melted!!!
    Boggle!
    Must have been a Harley mechanic.
    Not used to plastic and stuff.
    Fulliautomatix, Oct 5, 2007
