This evening, brethren...
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Sep 5, 2007.
  1. .... I screwed up my courage to the sticking point, turned off my brain,
    selected the "mumblety-mumble years of experience" switch to "off", got
    the GTR to 60 of Her Majesty's Miles per Imperial Hour and grabbed the
    front brake with full might and main. Whilst standing on the rear brake
    pedal.
    Oh yes, a full-on ABS test.
    **** me.
    You can't half stop quick when you need to.
    Honda GL1000K2 (Fallen apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Suzuki TS250 "The Africa Single" Honda ST1100 wiv trailer Norton 850 Commando
    Kawasaki GTR1400
  2. Wicked Uncle Nigel
    You'd stop quicker without ABS
    wessie, Sep 5, 2007
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, wessie
    *You* might.
    I definitely wouldn't.
    Kawasaki GTR1400
  4. Wicked Uncle Nigel
    R Guest
    <snip excessively long and boring sig>
    Man and machines eh...
    We put inordinate amounts of trust in someone *else's* engineering
    expertise, then expect it, after being assembled by yet another A.N.Other to
    work faultlessly.
    Best of luck I say...
    R, Sep 5, 2007
  5. Wicked Uncle Nigel
    christofire Guest
    Not if he's sliding down the road. That takes at least 80m. DAMHIKIJKOK?
    christofire, Sep 5, 2007
  6. Wicked Uncle Nigel
    Not in the wet in a sudden panic stop situation.
    The K1100 ABS only cut in twice. Both times it saved grief.
    Hog, Sep 5, 2007
  7. Wicked Uncle Nigel
    Steve Parry Guest
    In
    "Use the force, Luke"
    Me, I'll trust the ABS on a pissy wet road in a panic :)
    Steve Parry, Sep 6, 2007
  8. Wicked Uncle Nigel
    MikeH Guest
    BTDT
    What used to amaze me was how hard you had to brake to get the ABS to
    come on in the dry.
    On my early Ks I couldn't get the front ABS to come on at all in the dry
    due to the two-handed front brake. I always suspected it didn't actually
    work and the canister was a dummy.
    MikeH, Sep 6, 2007
  9. Wicked Uncle Nigel
    Rich B Guest
    I haven't had the ABS on the B12 kick in at all under normal riding.
    I did try it on the back brake once, in the wet, just to see what
    happened. I was expecting the kind of juddering through the pedal
    that you get with ABS on a car, but it was a curious lurching
    sensation - the pulses were around half a second apart. Strange.
    I'm happy it's there - it doesn't seem to interfere with normal
    riding, and it may just save my bacon if I have to do something
    panicky in the wet. I'm not looking forward to bleeding the bastard
    thing, mind.
    Rich B, Sep 6, 2007
  10. Wicked Uncle Nigel
    ginge Guest
    Did you ever find out if the white helmeted ones were going to take
    things further, or forget it all?
    ginge, Sep 6, 2007
  11. Wicked Uncle Nigel
    christofire Guest
    Yes, I did.
    christofire, Sep 6, 2007
  12. Wicked Uncle Nigel
    ginge Guest
    Hmm, your reply doesn't make things sound too good. :-(
    ginge, Sep 6, 2007
  13. Wicked Uncle Nigel
    ABS saves you in the sudden and unexpected situation, those when riders
    often go down.
    Ducati's ABS2 takes it to the limit of tyre adhesion beating 1G.
    Hog, Sep 6, 2007
  14. Wicked Uncle Nigel
    Well, yes. I think we sorted that out c2001 just after darsy and I bought
    ABS equipped bikes. Just thought I'd have a re-run for the entertainment
    value. Got some biguns, too.
    wessie, Sep 6, 2007
  15. Wicked Uncle Nigel
    Talking of Clarkson, he got off...
    http://news.bbc.co.uk/1/hi/england/6982514.stm
    Is this Nick Freeman known to UKRM?
    wessie, Sep 6, 2007
  16. Wicked Uncle Nigel
    You'll be ok on snow covered roads then...
    Andy Bonwick, Sep 6, 2007
  17. Wicked Uncle Nigel
    Catman Guest
    I'm hardly the greatest authority, but IWHT that was where the real
    issue started.
    116 Giulietta 3.0l Sprint 1.7 156 TS 145 2.0 Cloverleaf 156 V6 2.5 S2
    www.cuore-sportivo.co.uk
    Catman, Sep 7, 2007
