When you are doing a major overhaul, you should pause at the point of head attachment: With the head gasket in place and the head torqued down, BUT, before the top end is complete (before rocker boxes, push rods, overhead cam is installed) you can do the following cylinder leakage test to prove the integrity of head gasket and valve seating: Make a special tool (air injector) from an old spark plug. Gut it and braze weld a quick release air fitting. Screw this air injector into each cylinder and apply 20 psi. Crank position is unimportant! With the exhaust ports, intake ports and the spark plugs open (except the cylinder under test) you can prove the following: Head gasket seal. Listen for leakage in adjacent cylinders, and around the exterior junction. You can inject some penetrating oil it will make a sizzling noise where the leakage is, if any. Exhaust valve seating. Listen and actually feel any escaping air at the exhuast port of tested cylinder. Intake valve seating. Listen and feel for escaping air at the intake port of tested cylinder. Test all cylinders this way, then finish assembly. This will save a LOT of hours. You can find and fix troubles before you finish the job and find out the hard way. This tip has never before been published, anywhere. Nomen the megaposter
