This R1 front end...........
Discussion in 'UK Motorcycles' started by Nige, Apr 13, 2010.
  1. Nige
    The 10mm is how much travel isn't used. So the distance between the
    cable tie & the bottom of the forkleg (the 'bumpstop'). You don't need
    to know how much travel /is/ used, or how far the cable tie moves.
    Krusty, Apr 14, 2010
  2. Nige
    Nige Guest
    Yeah, got it, my manual says turn the screw all the way clockwise counting
    clicks, then count clicks anti-clockwise, clockwise decreases damping.
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, Apr 14, 2010
  3. Nige
    Nige Guest
    Right, just took it out & what a difference right away, had to slacken off a
    bit of front preload, then wind a bit back in, but crikey it feels so much
    better.
    Factory settings apart from both pre-loads. Fely bang on fro road riding
    Ta matey
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, Apr 14, 2010
  4. Nige
    davethedave Guest
    davethedave, Apr 14, 2010
  5. Nige
    What was the rear sag before you changed it, just out of interest?
    That's easy for you to say.
  6. Nige
    Gyp Guest
    Rump in spinach?
    Gyp, Apr 14, 2010
  7. Nige
    Nige Guest
    Not a lot to be honest. The ring selector was 2 notches harder.
    Feels fantastic now, the front was wound into just 2 rings showing, now it's
    just a smidge under 6
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, Apr 14, 2010
  8. Nige
    Nige Guest
    Following Krstys advice mines as tight as a nuns chuff now :)
    It'll needed a bit of twiddling for track, but so what, i have all the
    optimum settings written down :)
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, Apr 14, 2010
  9. Nige
    Simon Wilson Guest
    Aloo aloo aloo.
    Simon Wilson, Apr 14, 2010
  10. Nige
    Nige Guest
    I fear new batteries are required in the bluetooth kb :)
    Nige, Apr 14, 2010
  11. Nige
    zymurgy Guest
    If you Biryani it in a wall, the settings were wrong ...
    Paul.
    zymurgy, Apr 14, 2010
