Those cheap Chinese HIDlights
Discussion in 'UK Motorcycles' started by Simon Wilson, Dec 8, 2009.
  1. Simon Wilson
    Simon Wilson Guest
    Are rather nice.[1]
    Until they decide to flame out whilst making progress home in the teeing
    rain.
    [1]Before you jump in WUN, my SO B6 has a glow worm for a headlight. The
    HID makes it quite a lot better, and it's definitely set low, not to dazzle.
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Simon Wilson
    <closes mouth>
    Wicked Uncle Nigel, Dec 8, 2009
  3. Simon Wilson
    'Hog Guest
    I have wondered if the bulbs wear out and if it is practical to carry spares
    'Hog, Dec 8, 2009
  4. Simon Wilson
    Simon Wilson Guest
    This one's brand new, so I don't know what's up. I certainly don't trust
    it at the moment.
    On the ST1100 I've got one HID and one incandescant so it's not too bad
    if one fails.
    On the B6 that's it. I'm at least going to carry a spare H4.
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Simon Wilson
    <realigns sights>
  6. Simon Wilson
    Catman Guest
    They do eventually, but should do about 2000 hours. You *could* carry a
    spare. They are a bit more fiddly to swap than normal bulbs [1], and you
    probably wouldn't want to try at the road side, simply cos of the chance
    of getting something on the 'glass'.
    [1] Depending, of course on the install. SWMBO GTV you can't even
    *think* about changing bulbs without a screwdriver. My Sprint ST is much
    the same.
    116 Giulietta 3.0l Sprint 1.7 GTV TS 156 V6 2.5 S2
    www.cuore-sportivo.co.uk
    Catman, Dec 9, 2009
  7. Simon Wilson
    Catman Guest
    Flame out?
    Catman, Dec 9, 2009
  8. Flame out?[/QUOTE]
    Arc extinguishes.
    Grimly Curmudgeon, Dec 9, 2009
  9. Simon Wilson
    Simon Wilson Guest
    Arc extinguishes.[/QUOTE]
    *ding*
    Simon Wilson, Dec 9, 2009
  10. Simon Wilson
    Catman Guest
    My money will be on the ballast unit.
    Have you got a pair, Simon?
    116 Giulietta 3.0l Sprint 1.7 GTV TS 156 V6 2.5 S2 GT 3.2 V6
    Catman, Dec 9, 2009
  11. Simon Wilson
    Simon Wilson Guest
    I've got three different ones now. I don't know if the ballasts are
    interchangeable.
  12. Simon Wilson
    Catman Guest
    All the ones I've had have been, but it's a simple check IYSWIM
    Catman, Dec 9, 2009
  13. Simon Wilson
    Geo Guest
    Was there a pun in there somewhere or do I just have a dirty mind?
    Geo, Dec 9, 2009
  14. Simon Wilson
    Catman Guest
    The latter, sorry.
    *Mrs* Simon, OTOH......
    Catman, Dec 9, 2009
  15. Simon Wilson
    frag Guest
    took a blunt brush and painted...
    There is a cure to most of these dazzling HID lights (and not the one's WUN
    is thinking of).
    If you look at an H3/4/7 bulb the end is painted black to prevent any direct
    light shining out.
    The HID bulbs don't have this, hence they chuck light everywhere.
    Simple solution is to get some high temp black paint and dip the end of the
    HID bulb in it.
    Reduces dazzle down to "slightly mucky halogen headlight" levels, much much
    better.
    I suppose a better solution would be to use silver paint followed by black
    paint to make sure the light is reflected rather than absorbed by the black
    paint and heating the bulb glass up.
    frag, Dec 10, 2009
  16. Simon Wilson
    M.Badger Guest
    M.Badger, Dec 13, 2009
  17. Simon Wilson
    frag Guest
    I wish that was a wiki. There are so many "if"s, "but"s, "maybe"s, "in
    general"s in there, and so many half truths it's rather funny to read it.
    Anyway, I've just finished fitting them to my M3 after completely removing,
    dismantling and cleaning the headlights.
    Luckily the headlights are the projector type so swapping from halogen to HID
    doesn't affect the beam shape.
    Chucked the bulbs in to start with and there was far too much light being
    thrown outside the beam. After pulling them to bits the lenses had a thin
    covering of white sort of powdery stuff on them. Wierd. Possibly come from
    bulbs that had blown and broken their glass.
    All sorted now though.
    frag, Dec 13, 2009
  18. Simon Wilson
    Catman Guest
    We did this last time, to general cries of 'peer review?'
    Catman, Dec 13, 2009
