Throttle cables - spot the twit
Discussion in 'Classic Motorcycles' started by Guest, Sep 12, 2003.
  1. Guest
    Guest Guest
    I took so much care: new cables, hung up carefully so that the oil ran
    through from end to end - perfect! Should last for ages.
    Six months on, I find out that they're beginning to stick a bit, and
    further research shows that you're not supposed to lube post 1982 BMW
    cables as they have a liner. Rats!
    Are they shot? Have I been a complete pillock? More importantly, is
    there any way to recover from this - washing in petrol for example?
    If I do manage to get the oil out, will the linings shrink back to the
    right size again?
    HELPPPP! At this rate I'll be opening a trade account with Sherlocks...
    Regards,
    Simonm.
    Guest, Sep 12, 2003
  2. Guest
    Sean Guest
    Thats generally how it goes.
    Ah yes. Ahem. Not just Beemers either. I bought a clutch cable for the XJ.
    Not genuine Yamaha. I then did what I always did with new cables before
    fitting, lubed it. Frigging thing siezed within months. It was lined. The
    little sheet of paper that came with it recommended only a teflon based dry
    lube. Pah to that thought I.
    Probably
    Nope. You've not tried to flush it yet.
    This would probably wreck it utterly, but no harm in trying after you've
    bought a new set.
    You've softened the lining so it has swollen. Probably won't shrink back,
    probably grooved, 'picked up' into the cable etc.
    Well, at least you may get a discount.
    Sean, Sep 12, 2003
  3. you'll be lucky. I gather that what happens is that the oil causes the
    liner to swell.
    for a BM, try MotorWorks (http://www.motorworks.co.uk/)
    Austin Shackles, Sep 12, 2003
  4. Guest
    Timo @ work Guest
    Oops. You in IT[1]?
    No, you should still be able to hang the washing from them or use them
    in an equally supportive role.
    Oh, as a clutch cable? They're Donald Ducked for that mate, the liner
    doesn't like oil AFAIK.
    Nope, AFAIK they swell up and soften - it's the softening that's the
    problem.
    Sounds like a good idea, that :). Get yerself some 'featherlight'
    cables, they're well worth it.
    [1] Only read the manual if after you screwed up the job.
    Timo @ work, Sep 12, 2003
  5. Guest
    Steve Parry Guest
    Steve Parry, Sep 12, 2003
