Timing retardation eliminators?
Discussion in 'UK Motorcycles' started by Lozzo, Nov 26, 2005.
  1. Lozzo
    I've seen them advertised on eBay for my Gixer 1000, and am curious as
    to just how much of a difference one makes to the driveability of the
    bike once fitted. At 27 quid they seem to be a bit of a bargain if they
    does all they claim in the description.
    Can anyone who's bought and fitted one give me more of a clue?
    Lozzo, Nov 26, 2005
  2. Lozzo
    I haven't, but let me know your findings once you do.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Nov 26, 2005
  3. Lozzo
    Ace said...
    I might just risk 27 quid and find out for myself. I'll lend you it so
    you can try for yourself before buying, if I think it makes a
    significant difference.
    Lozzo, Nov 26, 2005
  4. Lozzo wrote
    Depends how far it retards it and how spot on your bike was in the first
    place.
    Snake oil imho.
    steve auvache, Nov 26, 2005
  5. Lozzo
    steve auvache said...
    Apparently the ignition is retarded in 1st and 2nd to help eliminate
    wheelies under hard acceleration, the TRE bypasses this and allows the
    engine to function as it would in any other gear, making it harder
    accelerating. Some claim to also smooth the power delivery and make the
    bike more rideable, as the throttle can be a little bit on/off at low
    speed. Some also do away with the top speed restrictor, allowing the
    bike to go over the "gentlemen's agreement" 186mph, not that they are
    capable of much more than that anyway.
    I don't think so, they certainly make a difference but I'm just
    wondering if make 27 quid's worth of difference.
    Lozzo, Nov 26, 2005
  6. Lozzo
    ginge Guest
    I've not bought one, but basically they set the resistance on a few
    wires to fool the bike into thinking it's always in 4th gear, no dulling
    down of the engine in the lower gears, and no electronically limited top
    speed in 6th.
    ginge, Nov 26, 2005
  7. Lozzo
    ginge said...
    I know what they do, I'm just wondering if it's really worth buying one.
    Lozzo, Nov 26, 2005
  8. Lozzo wrote
    Yebbut an digital throttle is inherent in these new fangled high revving
    multicylinder jobbies. It is one of their few delights.
    If 50% throttle is going to deliver enough grunt lift the front wheel
    then why tamper with the effect at 80% is the way I see it.[1]
    Mind you if yer right wrist was doing what it ought to be doing and
    concentrating on the job in hand this wouldn't be an issue would it?
    [1] I feel there is much to be said for examining manufacturers settings
    in this respect and many bikes could be turned down even more when the
    power simply wasn't usable but then that is traction control and that is
    a heinous crime and I reject it utterly.
  9. Lozzo
    Eiron Guest
    Sixpence worth of resistors and a couple of matchsticks will do the same
    job.
    Eiron, Nov 26, 2005
  10. This was mentioned on here a long time ago. Mr Gower had one on his
    GSXR1000 IIRC. The circuit diagram was printed as well. My mate has one on
    his Busa. All I can remember is it running poor in neutral because it
    overrides this setting as well as the first three gears.
    eric the brave, Nov 26, 2005
  11. Lozzo
    eric the brave said...
    I'd buy one. I want it to be right if I'm going to do it at all.
    Lozzo, Nov 26, 2005
  12. Lozzo
    Fr Jack Guest
    Frag has one on his VStrom, IIRC
    Cheers!
    Fr Jack
    B12S (coming soon) 90 CB450DX (The Moped)
    FRJACKUKRM AT GMAIL DOT COM
    skype: fr.jack (without the dot)
    We'll open up your eyes,
    just to check that you're asleep, again
    Fr Jack, Nov 26, 2005
  13. Lozzo
    Nick Guest
    I have one on my VStrom - I took it off, then put it back on - it is better
    with it on..
    Nick
    Nick, Nov 26, 2005
  14. Lozzo
    Molly Guest
    This old chestnut again.
    Look here:
    http://sportsbike.org/technical/tre.htm
    It does make a difference, the throttle is certainly snappier on the K1.
    Molly, Nov 27, 2005
  15. Lozzo
    Molly Guest
    Yes, I've got a switchable one.
    Molly, Nov 27, 2005
  16. Lozzo
    Dan L Guest
    A few of the Zephyristi have them fitted and reckon they make quite a
    difference.
    Dan L (Oldbloke)
    Space in shed where NSR125 used to be
    BOTAFOT #140 (KotL 2005), X-FOT#000, DIAABTCOD #26, BOMB#18 (slow), OMF#11
    Dan L, Nov 27, 2005
  17. Lozzo
    Molly said...
    Did you buy or make yours?
    Lozzo, Nov 27, 2005
  18. Lozzo
    Molly Guest
    I bought it from the states for about £25,
    Molly, Nov 27, 2005
  19. Lozzo
    Daz Guest
    No.
    Ask Crescent for their opinion, seriously. Do you really want 1st,
    2nd and 3rd to be more snatchy? Ignore any claims of extra power,
    it's bollocks.
    I'll also put my faith in Suzuki applying the retard for a good
    reason. Probably based on feedback from test riders that know far
    more than you or I about the ridability of a bike.
    Daz, Nov 27, 2005
  20. Lozzo
    Daz Guest
    On Sun, 27 Nov 2005 09:08:14 -0000, "Molly"
    Why would you want a throttle like an on/off switch right when you're
    getting on the power out of a corner?
    Daz, Nov 27, 2005
