TLR owners
Discussion in 'Australian Motorcycles' started by Spud, Aug 3, 2003.
  1. Spud
    Spud Guest
    Gday all
    Just a quick question for the TLR owners out there,I know that the tank
    holds 17 litres but when does the low fuel warning light come on and how
    many kilometres can I expect to travel before completely empty.
    Cheers Spud.
    Spud, Aug 3, 2003
  2. Spud
    Theo Bekkers Guest
    "Spud" wrote
    Have you considered noting the odo reading when the light comes on and
    then seeing how much fuel it takes when you fill up. Borrow a friends
    calculator if you can't work it out in your head. If your head starts
    to hurt, ask your friend to operate the calculator.
    Theo
    Theo Bekkers, Aug 3, 2003
  3. Spud
    vifer Guest
    Use the coke bottle method.
    Carry a one little coke bottle full of petrol, ( dont fill it to the brim) ,
    when you're coming close to low.
    Also carry a little notebook and make notes.
    When bike comes to a splattering halt , fill the bike with fuel you were
    carrying and hope there's a servo within your 1 litre range.
    trial an error, easy..
    vifer, Aug 3, 2003
  4. Spud
    Doug Cox Guest
    I think the last person to clean your coffee machine may have left some
    caustic in it...
    Doug Cox.
    Work to ride, Ride to work...
    Doug Cox, Aug 3, 2003
  5. Spud
    Doug Cox Guest
    Brick wall?...
    Doug Cox.
  6. Nah, its Harsh Week, remember???
    big
    Iain Chalmers, Aug 4, 2003
  7. Spud
    Theo Bekkers Guest
    "Doug Cox" wrote
    I thought nobody is that stupid, must be a troll.
    I was wrong.
    Then again, carrying a coke bottle full of petrol in your pocket
    is........... Do coke bottles and caps not dissolve in petrol? I had
    to ask, never tried it myself.
    Theo
    Did you see that Clem, I was wrong.
    Wanders off to clean coffee machine.
    Theo Bekkers, Aug 4, 2003
  8. Spud
    Johnnie5 Guest
    petrol has a dye in it so has faded from the UV light
    same thing happened to my kero in about 1 week
    Johnnie5, Aug 4, 2003
  9. Spud
    vifer Guest
    Have done this a few times out of necessity.And of course to work out the
    tank range on an unfamiliar bike.
    Interesting also I've noticed is the volume variation between different
    petrol bowser's(servo's). There's a BP not far from where I live and I
    swear I can never squeeze more than 19.5 litres in the VFR tank.
    Where other servo's I have no problem clicking it well over 20.5 litres.
    Given the same state of residual fuel in the tank and the quality of fuel
    the same, this has to point to a calibration prob. Who's ripping off who?
    If you going to use a plastic coke bottle, don't fill it up to the top.
    And if you're paranoid about the petrols' volume expansion, drill a very
    small hole in the top and tape a small balloon over it.
    (Just have your story prepared in case you get pulled over by the
    constabulary and they happen to notice the coke bottle sticking out of your
    front pocket. "Excuse me Officer, Molotov ? No. Don't know who Molotov
    is".)
    vifer
    97 vfr750
    - where back in the uni days, used the bike's choke more to hobble that last
    300 metres looking for a servo than to warm the bike up in the morning. -
    vifer, Aug 4, 2003
  10. Spud
    Spud Guest
    Thanks Paul don't have a manual but you have answered what I was after.
    Cheers Spud
    Spud, Aug 4, 2003
  11. Spud
    Doug Cox Guest
    Never underestimate the human capacity for stupidity.
    Coke'll clean the rust from your tank...
    Doug Cox.
    Doug Cox, Aug 4, 2003
  12. Spud
    andrew Guest
    OK - you deliberately run out of fuel. So what's the remedy when you
    run out of fuel at an intersection an get cleaned up by a bus?
    Any handy hints?
    Andrew ;)
    andrew, Aug 5, 2003
  13. Spud
    Theo Bekkers Guest
    As someone else has already pointed out, he did say "splattering
    halt".
    In my experience you do get a few warning coughs. Some cars even have
    them designed in. My older son has a Hyundai (yes, I know, I blame his
    mother) Grandeur XG with every electronic bit of gizmo that they could
    fit in. When the fuel gets low a light comes on in the gauge, that's
    pretty normal. If you ignore the light for a while it will start
    flashing at you. If you still ignore it it will cut the ignition for
    one second every minute (unless you're idling) until you go to a fuel
    station (or run out). So they're not very concerned about your bus.
    Theo
    Theo Bekkers, Aug 5, 2003
  14. Filled up at a servo in Albury and told the cashier to get the pumps
    checked. Just put 20.5l into a 19.5l tank. She said, "Gee, you must
    have been running low."
    Pisshead Pete, Aug 5, 2003
  15. Keep out of the city!
  16. "No one ever went broke underestimating the intelligence of the
    American people" -- PT Barnum
    "Only two things are infinite: The universe and human stupidity,
    and I'm not quite sure about the former" -- Einstein
    big (#2 is probably mis-attributed, but pretty funny anyway ;-)
    Iain Chalmers, Aug 5, 2003
  17. Spud
    andrew Guest
    Cool - so your best bet is to avoid intersections and get yourself a
    Hyundai - which I'm guessing would need a 2 litre coke bottle if you
    wanted to test the fuel range. I'm learning so much.
    My memories hitting reserve on the XJ750 were that it coughed a few
    times also - but not with enough notice to get me out of trouble. The
    first coughing fit was quite an eye opener (on a hairpin on Bells line
    of Road). After that I always changed to reserve when nearing the limit
    of fuel range and then started looking for a servo.
    Andrew
    andrew, Aug 5, 2003
  18. Spud
    Why bother ever switching your tap back to main tank? (If you don't actually wait for it to run onto reserve,
    and only use the odometer) You're just wearing it out unnecessarily!
    Knobdoodle, Aug 5, 2003
  19. Spud
    vifer Guest
    Theo Bekkers wrote:
    Going back 10 years, reminds of the media expose' of a select few taxi
    drivers who were found "adjusting" their taxi meters by fiddling with their
    transmission/speedo drive sprockets.
    Back in the old mechanical flip-over digit days.
    Meter always appeared to be sealed as well.
    vifer
    vifer, Aug 5, 2003
  20. Spud
    Nev.. Guest
    Why would it ever need to be necessary to run a tank dry in order to determine
    mileage? Surely you can measure it using the first litre of fuel burned,
    rather than the last. Manufacturers don't keep tank capacity a secret.
    Petrol stations don't keep the amount of fuel dispensed a secret. Never plan
    to use the last litre of fuel. Never decide to skip this one and stop at a
    petrol station in the next town.
    Nev..
    '02 CBR1100XX #2
    Nev.., Aug 5, 2003
