scared myself silly on a bend in the wet. Sulk.
I'm sulking too. took the turbo for an MOT. got to the end of the road and realised it needed air in the tyres (only pumped up last week) as it was cornering like a BARGE. got to the garage, topped up with air, realised an indicator wasn't working. got to the MOT station, replaced the bulb, didn't work, got Andy to fix the wiring. it then failed the MOT on the anti dive appearing to be on all the time. I'm beginning to think the damn thing is cursed. -- Adie (replace spam with nickname to reply) UKRM FAQ: http://www.ukrm.net/faq/ keeper of the ukrm faq for my sins YZF-R1 : ZX9R E1 : GPz 750 turbo MRO#11 BOTAFOF#7 BOTAFOT#130 DIAABTCOD#17 MIB#24 YTC#16 BOB#15 ex-UKRMMA#22 BOMB#11
Bugger off, then I'll end up wishing for rainy periods to practice in, and that is NOT a healthy mindset. I'm almost tempted to get a couple of lessons in the rain if that's possible to do.
Sounds good to me. Let the weather dictate whether your ride is fun in the dry or, as Champ would say, twice the fun at half the speed in the wet. I'm sure it is.
It failed because it's using up all bar about the last inch of fork movement before you even consider braking. The mechanic in the workshop next door suggested the anti-dive *can* cause an identical problem and the quickest way to eliminate it from any fault finding is to remove it and blank off the ports. The only thing I found wrong when we were at home was that it had absolutely no air in the forks which means the initial pre-load was missing. I suspect it's a combination of incorrect fork oil level and no air because if the anti-dive was sticking on then the forks wouldn't be sagging. I think that Adie's asked Lozzo to have a quick look at it but if I had any time spare I'd check that the oil level is correct, stick a couple of 1" spacers on top of the springs to load them up a bit and blank off the anti-dive. They're forks ffs, not jet engines.
If the anti-dive is on all the time this could translate as not having any fork travel which would be a reason to fail. However, anti-dive forks should not be tested with the brake applied. The front wheel should be placed against a solid object (like a wall) to test the damping.
That's what he did. He was very apologetic about having to fail it but he was concerned that with most of the fork travel being awol hitting a bump mid corner could spit Adie off the bike. I'm pretty certain it'll be easy to fix but I've only got two days off before we head to Chimay so I can't even start to look at sorting it out.
Sure is, spinning up the rear in the wet at speed is desperately little 'fun' too. Wet leaves in the autumn are even better as the bike kicks out disconcertingly at the same time. P.
Ooh. Did madam get the arse end all waggly with the rear wheel going all spinny? Good innit? After, not during, obviously. I'm definitely not used to a working clutch on the Wing. In its defence, it was over a white line, in the rain. In my defence, I was riding like I'd stolen it.
Madam did not. Madam was on a medium throttle at about 40mph, felt a twitch as if the front had slipped an inch or so and like a moron, she shut the throttle. Schoolgirl error by all accounts. I don't think er5s DO spinny.
