TOG down. Bollocks.
Discussion in 'UK Motorcycles' started by The Older Gentleman, Jan 13, 2006.
  1. The Older Gentleman
    Tosspot Guest
    Fwiw, I've done exactly the same. Those vacuum/fuel hoses are too short
    on Trophies. In the end I replaced mine with ones a god few inches
    longer to make the job easier.
    Still, you're ok, you broke your duck and in a few months all will be
    well with the world again. At least in time for the French run :)
    Tosspot, Jan 14, 2006
    #61
  2. Actually, I've run over the events in my mind, and I relaise that I
    *did* have the fuel tap the correct way round. But the vacuum hose was
    definitely kinked, and I was switching the thing onto Prime when it
    happened. The Trophy farts and misses for an age when running onto
    reserve, and Prime just seems to get it firing properly quicker.
    I thing the hose must have been near to kinking and then kinked entirely
    on a bump or something. So not properly routed anyway. As you say, it's
    a bit of a bugger to get right.
    The Older Gentleman, Jan 14, 2006
    #62
  3. She's a clever and perceptive lady, your missus?
    Paul Corfield, Jan 14, 2006
    #63
  4. The Older Gentleman
    lushhead Guest
    <snigger>
    Clumsy ****
    lushhead, Jan 14, 2006
    #64
  5. The Older Gentleman
    maybe looking in the back of his garage wouldn't be a good idea...
    Pip Luscher, Jan 14, 2006
    #65
  6. The Older Gentleman
    On Fri, 13 Jan 2006 19:38:18 +0000,
    Yep. Oh, and "give you a tenner for the biket".
    It is bloody slippery out there at present.
    #66
  7. The Older Gentleman
    We've got too much junk in there to squeeze an extra body in.
    Andy Bonwick, Jan 14, 2006
    #67
  8. Pip Luscher wrote
    Cor innit just.
    This week has been a no grip zone for me. It has got so bad I am even
    tempted to have a look to see if the tyre pressures are close enough or
    if the bearing have actually collapsed yet.
    Only tempted mind, I wouldn't want to be called a safety nazi.
    steve auvache, Jan 14, 2006
    #68
  9. The Older Gentleman
    Too bloody right. There's enough of that about as it is.
    #69
  10. The Older Gentleman
    Tim Guest
    In message
    [snip]
    Silly sod. Glad you're ok.
    Tim, Jan 14, 2006
    #70
  11. The Older Gentleman
    You're the man with the local knowledge when it comes to bodies under
    patios.
    #71
  12. The Older Gentleman
    ....and have a couple of months off work. Which happened to be at just the
    right time.
    platypus, Jan 14, 2006
    #72
  13. The Older Gentleman
    While you're fossicking around under the tank, remember to clear out the
    little filters in the T-pieces between the carbs.
    #73
  14. The Older Gentleman
    That would presuppose TOG being more intelligent than The Doctor.
    #74
  15. Never even knew such a beastie existed. I will, ta.
    The Older Gentleman, Jan 15, 2006
    #75
  16. You ain't keeping up here, are you?
    I've bought all the bits - you're right, they were a horrifying price,
    like over £600. But I'm not claiming.
    With excess and loss of NCB and a loaded premium afterwards, it's not
    worth it for that sort of money. If it had been over a grand, I probably
    would have.
    #76
  17. The Older Gentleman
    platypus, Jan 15, 2006
    #77
  18. The Older Gentleman
    wessie, Jan 15, 2006
    #78
  19. The Older Gentleman
    deadmail Guest
    But, of course, you'll tell your ins.co about the accident even though
    you didn't claim...
    deadmail, Jan 15, 2006
    #79
  20. The Older Gentleman
    deadmail Guest
    I suspect it would count if it was reported.
    Regarding the difference between this and dropping a bike when cleaning
    it, well... Since insurance prices are set to reflect the risk that the
    ins.co are exposing themselves to, I'd suggest that there's less risk
    from a clumsy slip than there is from, say, a half-blind bloke, slowly
    losing his marbles, being distracted and while fumbling for something
    failing to see what's going on around him...
    #80
