too much oil
Discussion in 'UK Motorcycles' started by Vass, Aug 29, 2010.
  1. Vass
    Vass Guest
    just changed the oil and filter, appears I may have put about 1/4 ltr too
    much oil in as the sight glass is full instead of half full
    Do I need to drain some out or will it be ok ?
    ('06 R1)
    TIA
    Vass, Aug 29, 2010
  2. I've always worked on having the sight glass just full to the top, but
    I've no idea what the manual for the R1 says. Doubt if 250cc will make
    much difference.
    Jut thrash the tits off it to burn some of it away.
    The Older Gentleman, Aug 29, 2010
  3. Vass
    more likely any surplus would blow into the airbox via the engine
    breather - that's what happens on a boxer twin, at least.
    Although, as you say, 250ml is not likely to matter. If Vass is worried
    he could just unscrew the oil filter, pour the contents back into the
    bottle which would get rid of most of the 250ml.
    wessie, Aug 29, 2010
  4. Vass
    A boxer has some pretty big crankcase pumping effects though; an
    inline four has hardly any, assuming that there isn't too much
    blow-by.
    I reckon you're right about it no mattering, FWIW.
    Pip Luscher, Aug 29, 2010
  5. Vass
    Vass Guest
    won't all the oil piss out if I do that?
    Vass, Aug 29, 2010
  6. No. The oil filter chamber is pressure fed. It's not like removing a
    sump plug.
  7. Vass
    ts Guest
    For what it's worth, I once drained off about a quarter of a litre too
    much oil by unscrewing the drain plug _carefully_, until it allowed a
    gentle drip-flow past the plug. It helped with warm oil in the
    crankcase. If you should ttry this, it is of course useful to keep a
    bicket large enough to catch all the oil, in case you should be unlucky
    with the threads.
    ts, Aug 29, 2010
  8. Vass
    Beav Guest
    If you let the bike stand without the the oil filler cap in place, then
    start the bike, you'll be rewarded with at least 1/4 litre of oil being
    automagically deleted from the sump and deposited on your left trouser leg.
    Re-fit cap, and to quote that twat Tommy (whatever the **** his last name
    is) "Job done"
    Beav, Aug 30, 2010
