Toolkit/Multitool recommendations
Discussion in 'UK Motorcycles' started by Kiran, Apr 5, 2005.
  1. Kiran
    Kiran Guest
    As the GSXR I bought came without the underseat toolkit, I am thinking
    of getting a few tools to keep under the seat, for emergencies and the
    like.
    So what should I get? Some kind of multitool or just get a few decent
    individual items? If the latter, what would I need - I'll assume 8, 10,
    12, 13 and 14mm, spanners, pliers, screwdriver and allen keys. Anything
    else?
    Ta
    Kiran
    Kiran, Apr 5, 2005
  2. Kiran
    The only 'tool' I carry is my AA membership card.
    CT, Apr 5, 2005
  3. Kiran
    Multitools are shit in this context. No discussion.
    Go the individual items route (the ones you've listed with the addition
    of a plug spanner); if it's just as a get you home toolkit then something
    cheap and cheerful (brands like City, Rolson, Laser and the like) from a
    motor factors will be good enough.
    If it's as part of a toolkit for home buy something a bit better (Teng,
    Sealy, Sykes, Kamasa etc.)
    You could probably do a fair quality get you home, minor servicing kit
    for about £20-£30.
    sweller, Apr 5, 2005
  4. Kiran
    Catman Guest
    AA / RAC / Green flag* membership
    *delete as applicable.
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 155 TS
    www.cuore-sportivo.co.uk
    Catman, Apr 5, 2005
  5. Kiran
    A lot of annoying gremlins or en route adjustments are easily done by the
    rider and don't need recovery.
    I'm not advocating rebuilding the bloody thing by the roadside but in a
    large number of cases breakdown recovery aren't going to come out to
    assist you adjust something.
  6. Kiran
    Kiran Guest
    So, err, you'd call out the RAC or whoever to undo two allen bolts to
    take off the seat? Or to tighten up a numberplate that's literally
    about to fall off? Fair enough, better get a decent book through as you
    could be in for long wait.
    Anyway, I have breakdown cover with Auntie Carole.
    Kiran
    Kiran, Apr 5, 2005
  7. Kiran
    Kiran Guest
    Yeah, that's what I was thinking. I saw some genuine Suzuki toolkits on
    ebay, but they were going for about £25 plus postage [1]. I'll have a
    look this weekend and get a few bits.
    I've got some fairly decent stuff for home use but this is stuff I want
    to be able to put under the seat and forget about until I need it.
    Kiran
    [1] Which is ridiculous given that they're probably very poor quality
    items.
    Kiran, Apr 5, 2005
  8. In uk.rec.motorcycles, Kiran amazed us all with this pearl of wisdom:
    http://www.busters-accessories.co.uk/proddetail.asp?prod=MMTK
    Whinging Courier, Apr 5, 2005
  9. Kiran
    Err...
    :eek:)
    CT, Apr 5, 2005
  10. Kiran
    Kiran Guest
    Kiran, Apr 5, 2005
  11. Kiran
    Catman Guest
    YMV. I've never had anything that I could fix by the roadside on the bikes.
    I do carry tools in the cars though....
    Catman, Apr 5, 2005
  12. In uk.rec.motorcycles, Kiran amazed us all with this pearl of wisdom:
    Bugger. I didn't see that <g>
  13. Kiran
    Catman Guest
    Why would I need to do that? Min'es held on by a key. Not really a lot of
    point in putting your tools under the seat if you need tools to get the
    seat off....
    Well, I tend to check that things like that are not going to fall off before
    I leave home, where all my tools, anyway.
    If it did then work it's way loose, I'd either take it off completely, or if
    I couldn't do that for lack of tools, I'd chance getting it home.
    Or not. Never taken more than 40 mins recovery time when I've actually been
    waiting as opposed to at a client (this was for the cars)
    Cool
    Catman, Apr 5, 2005
  14. Kiran
    CT, Apr 5, 2005
  15. Kiran
    Ben Guest
    You'd be better off spending 25 quid on cheese.
    Ben, Apr 5, 2005
  16. Kiran
    Monkey Guest
    Angle grinder. Duh.
    Monkey, Apr 5, 2005
  17. Kiran
    TOG Guest
    Heh. Has Sir checked Ebay item 7966102343 yet? I have a happy feeling
    it'll make a damn sight more than 25 quid.
    Seriously, though, you want tools to do the following tasks: adjust
    chain, change a brake or clutch lever, change a throttle cable, and
    access behind the fairing (allen and screw fasteners, presumably).
    That'll cover 99% of what you might need to do on the road, away from
    home. Except punctures, of course.
    I'd also pack a roll of electrical or gaffa tape - incredibly useful at
    odd times - and a couple of spare fuses if the fusebox doesn't hold
    spares. And a pair of two of those polythene gloves they dole out at
    diesel pumps. If you have space, a pair of Mole grips is worth toting.
    I mean, they can be used to shift nuts that you haven't a spanner for,
    hold items steady while you do something else, and I've even heard of
    them being used as emergency gear levers.
    On the Ducati I carry a spare front brake lever, on the basis that if
    it falls over and breaks the clutch lever, I can get home, but a broken
    brake lever strands you. (Actually, the same unit is used on both sides
    on the Ducati. It's symmetrical, and you can just turn it upside down!)
    TOG, Apr 5, 2005
  18. Kiran
    Monkey Guest
    Not if you've fitted R&G crash mushrooms. Then you'll need a special deep
    14mm socket and a bloody ratchet handle to turn it with. Mutter mutter.
    Monkey, Apr 5, 2005
  19. Kiran
    'Hog Guest
    My Gixxer home brew kit includes a 36mm shifting spanner. Start from there
    (rear wheel spindle). Halfords do a decent cheap range that doesn't seem to
    rust badly.
    'Hog, Apr 5, 2005
  20. Kiran
    Bear says...
    Only because your chain adjuster bolts were seized solid through lack
    of use.
    Lozzo, Apr 5, 2005
