Top box suggestions for BMW K1200GT
Discussion in 'Australian Motorcycles' started by David, Aug 28, 2006.
  1. David
    David Guest
    Right, firstly, lets not revisit the last "top box" thread from a few
    months ago :)
    I am looking for suggestions for sourcing a top box to add to a 2004
    model BMW K1200GT.
    I currently have a Ventura rack & bag, which I want to replace with
    something lockable and large enough to hold 2 helmets or a briefcase.
    I have looked at the Givi E52 which while it fits the bill, carries a
    very heavy bill of approx $800 for the top box and mounting hardware, or
    $1,000 with the addition of brake lights and a passenger backrest.
    FWIW, the breakdown of the Givi E52 pricing is:
    E52 top box $579
    Rack $130
    Mounting plate $ 80
    Lights $ 99
    Backrest $115
    Any suggestions for cheaper alternatives ?
    Thanks
    David
    David, Aug 28, 2006
  2. David
    john doe Guest
    cheap top boxes? look up in the sky... its super doodle!
    john doe, Aug 28, 2006
  3. David
    David Guest
    Smee,
    Thanks for that.
    Do you reckon the mounting plate would go onto a ventura rack without
    major problems?
    David
    David, Aug 28, 2006
  4. David
    Boxer Guest
    Ventura racks are too fragile to mount a top box (in my opinion).
    Boxer
    Boxer, Aug 28, 2006
  5. David
    Marty H Guest
    and Eskys, just ask Nev
    mh
    Marty H, Aug 28, 2006
  6. David
    justAL Guest
    It's a good idea but the largest RJays case is similar to the E360 in size.
    Another route I've seen people take are Pelican Cases. A bit more at sub
    $400 prices and you'll still need to drill the boxes for attachments but the
    boxes are the most hardy pieces of luggage I've seen used.
    http://www.carryitcases.com.au/category131_1.htm
    Cheers,
    justAL
    justAL, Aug 28, 2006
  7. David
    sanbar Guest
    Isn't the 28-litre BMW box around the $600 mark? Plus you can use the
    ignition key ...
    - sanbar
    sanbar, Aug 28, 2006
  8. David
    David Guest
    Dunno, I never considered genuine BMW, usually poor value.
    I'll give the BMW dealer a bell.
    Thanks
    David
    David, Aug 28, 2006
  9. David
    Boxer Guest
    Depends upon how much you want to put in the top-box I suppose, looking at
    the original mounts on my K1100LT and from what I remember of the Ventura
    rack on my R1100S I would go with the OEM mounts every time.
    Boxer
    Boxer, Aug 29, 2006
  10. David
    JL Guest
    No argument. The more solid the better, and particularly so if you ride
    rough roads.
    JL
    JL, Aug 30, 2006
  11. David
    David Guest
    The ventura rack on the K1200 seems fairly solid. With a lot of
    pressure, I can only get a small amount of flex.
    I might try getting one of those cheap plastic boxes, like a lot of bike
    couriers use, and bolt that to the rack as a trial first.
    David
    David, Aug 30, 2006
  12. David
    Moike Guest
    If you want something really ugly.....
    http://tinyurl.com/fvy6m
    Moike
    Moike, Aug 30, 2006
  13. Look like the backend of a Ford Falcon
    Al
    Alan Pennykid, Aug 30, 2006
