Top tip
Discussion in 'UK Motorcycles' started by deadmail, Jan 2, 2006.
  1. deadmail
    deadmail Guest
    When messing around with mains wiring and insisting on working live...
    Make sure that the wire you've currently got in the cutters is the one
    that you think it is. If it's the ring main this is not a good thing.
    Still, looking on the bright side, the cutters were about 15 years old
    and had seen better days and the hole that was made in them make them
    very good at stripping insulation.
  2. *Snort*
    And you're supposed to be an electrickery eggspurt, too.
    Have we got a list for "First Suicide Bid Of The Year"?
    The Older Gentleman, Jan 2, 2006
  3. deadmail
    Ben Blaney Guest
    Ben Blaney, Jan 2, 2006
  4. deadmail
    gomez Guest
    Is mains lecky fatal then? I have survived two thrilling bouts of
    stupidity. Seven chances left?
    gomez, Jan 2, 2006
  5. deadmail
    gomez scribbled on the back of a napkin:
    It can be. Especially if you've got a dicky ticker.
    Dunno. Do you tend to cough up hairballs?
    Timo Geusch, Jan 2, 2006
  6. deadmail
    deadmail Guest
    Absolutely not, I studied electronics.
    And in this case it was complacency that caused the problem, well that
    and sheer bloody mindedness.
    Hardy a suicide attempt. An attempt at getting a Darwin award possibly
    'cos whilst the screwdriver I was using and the pliers I was using were
    insulated, the insulation on the cutters had worn off years ago.
    Fortunately when they cut through the live's insulation they'd already
    made good contact with the earth (because it threw the trip) and I
    didn't even get a tickle.
    I was quite impressed by my son who was sat playing something or other
    on his PC about five feet from me, he just said "are you ok", shortly
    followed by "what have you done, my PC's stopped"
  7. <VVBG>
  8. Still using fuses?
    Grimly Curmudgeon, Jan 2, 2006
  9. deadmail
    deadmail Guest
    No, the trip thing in the consumer box flipped over.
  10. Lucky you. It's possible you might have a breaker equipped box without
    an RCD covering the power circuits.
    Fwiw, I've cut RCD-protected cables a couple of times and the cutters
    have survived unmolested, which makes me wonder if your RCD (if there at
    all) might be buggered.
    If you do have one, test it now.
  11. deadmail
    deadmail Guest
    It's a split box with an RCD on some circuits but not this one; I had
    problems with a domestic appliance tripping the RCD so I took it off
    that circuit.
    In any case, if the cutter connection was from live to neutral then the
    RCD wouldn't have done anything.
  12. deadmail
    Robs Guest
    Firstly its not a poxy ring main! its a ring final circuit!
    Secondly why feck about with what you dont understand, dont you know you can
    only play with electrics these days if you give John Prescotts mates a large
    wedge of cash!
    Robs, Jan 2, 2006
  13. deadmail
    MattG Guest
    I did pretty much the same thing about 2 years ago. The bang and shower
    of sparks was most impressive.
    Took the rest of the day for my sight and hearing to return to normal.
    MattG, Jan 2, 2006
  14. deadmail
    A few years ago, my FiL got a pipe/cable detector for Xmas. Later the same
    day, he had some reason to drill a hole in the wall in the front room.
    Almost immediately, there was a muted *BLAPP* from somewhere under the
    plaster, and all the power went off...
    platypus, Jan 2, 2006
  15. deadmail
    MattG Guest
    That puts me in mind of a story I heard earlier today. I wonder if the
    original orator would like to share with the class...
    MattG, Jan 3, 2006
  16. deadmail
    Burnt emerged from their own little world to say
    An RCCB should. They are very sensitive. Just a few microamps difference
    between the L & N currents will trigger them. Simultaneously cutting
    through L & N mains conductors with a pair of snips should produce enough
    variation to trigger the device e.g the energy used to damage your cutters
    would not be returned through the device thus causing an imbalance in the
    coils.
    wessie, Jan 3, 2006
  17. deadmail
    gomez emerged from their own little world to say
    IIRC from my BTEC course 16 years ago, 50 milliamps at mains voltage
    through your heart can be fatal.
    wessie, Jan 3, 2006
  18. **** off, you know-nothing ****.
    Grimly Curmudgeon, Jan 3, 2006
  19. Element leakage.
    True. But as you cut the live the leakage through you would've tripped
    it. Moot point anyway.
    Fwiw, I've done the same for cooker and oven circuits, even for the UPS
    dedicated circuit, to avoid nuisance trips.
  20. deadmail
    I'm sure he would, with a bit of encouragement. Speak up! Stout fellow!
    platypus, Jan 3, 2006
