Top tip
Discussion in 'UK Motorcycles' started by deadmail, Jan 2, 2006.
  1. Typically set at 30mA, or 100mA for a whole house or upstream RCD.
    The cumulative leakage from cookers, PCs, immersions, can easily
    approach the trip setting if the entire non-lighting side of the CU is
    protected by a single RCD, so it's a question of practicality versus
    ultimate safety.
    For this reason, and to avoid nuisance tripping, I like to use RCBOs
    (RCD and MCB combined) where possible, especially on shower feeds.
    Grimly Curmudgeon, Jan 3, 2006
  2. Ah yes, good those things aren't they?
    I bought one years ago and it was the most useless piece of shit I've
    ever purchased.
    Mind you; I bet he didn't look to see if his hole was in a line h/v from
    a fitting.
  3. deadmail
    Any one I've ever tried to use has been absolute crap.
    He did, it wasn't.
    platypus, Jan 3, 2006
  4. deadmail
    Who you calling fat, Fatty?
    Anyway, it is far too recent to be funny yet. Let it mature for a
    while ...
    Pip, Jan 3, 2006
  5. deadmail
    muddy Guest
    <looks at watch>
    Well?
    muddy, Jan 3, 2006
  6. deadmail
    Sounds painful.
  7. deadmail
    I've done the look for fittings in line with the new hole trick but
    forgot to look on the other side of the partition wall with amusing
    results. It took me longer to repair the hole in the wall where
    everything blew outwards than the original job should have taken to
    complete.
    Andy Bonwick, Jan 3, 2006
  8. deadmail
    deadmail Guest
    Whilst 'Ring Final Circuit' may be the more correct term, 'Ring Main' is
    in wide use, including on the IEE website; who I presume know a little
    more about such things than you.
    If you read (and understand) my little story you'd see it wasn't through
    any lack of technical knowledge but through sheer ****-wittedness that
    the error occured. I understand enough to know a) what I needed to do
    and b) how I was doing it was both wrong and dangerous.
    The real reason that the problem occurred was because I was rushing
    things since spending my time lying on insulation in a confined space
    isn't how I wished to spend my bank holiday.
    deadmail, Jan 3, 2006
  9. deadmail
    deadmail Guest
    But surely a cut between live and neutral (not involving earth) would
    just look like a normal current flow since the flow would be simply
    between live and neutral hence the currents would balance.
  10. deadmail
    deadmail Guest
    Well I didn't feel the slightest flutter so suspect that I had managed
    to avoid touching a part of the cutters which was lacking insulation
    through luck.
  11. This has so many similarities with motorcycle maintenance gone wrong
    that it's scary.
    The Older Gentleman, Jan 3, 2006
  12. deadmail
    Robs Guest
    Is that why I earn a small fortune carrying out electrical installations
    every year!
    Maybe you should get some qualifications, you may be able to afford a decent
    bike then!
    Twat!
    Robs, Jan 3, 2006
  13. deadmail
    emerged from their own little world to say
    see Grimly's post about earth leakage through you[1] plus add in any losses
    to the environment as your cutters oxidize.
    [1] the whole idea of the RCCB is that it trips *before* you feel the
    effects of the leakage
    wessie, Jan 3, 2006
  14. deadmail
    Robs Guest
    So basically im right! A ring main is how the underground cables are run
    that supply your house!
    And are you sure the IEE know everything? Most of the big companies like MK
    are on the board and do tend to influence the regulations to favour there
    products etc!
    You understand enough! That will get you killed!
    Well thats how i spend most of my working life! shit isn't it?
    Robs, Jan 3, 2006
  15. and explains why I'm still waiting for a cable to be run through up
    the all rather than through the hall, up the stairs, across the
    landing...
    Adie
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4583091887
    Triumph 955iSS / ZX9R / GSF1200 bandit (for sale) / CG125
    Adrienne M Bonwick, Jan 3, 2006
  16. I mean, if it was an RCD protected circuit.
  17. Ah; a Cable Monkey.
    Wiring your relatives' garden sheds pays well, does it?
    You appear to know **** all. Perhaps you should get some basic
    education.
  18. Using the patented Mavis Beacon "Hunt&Peck" Technique, Robs
    So basic literacy isn't a requirement to be an electrician? Interesting.
    Wicked Uncle Nigel, Jan 3, 2006
  19. deadmail
    Robs Guest
    Im sorry thats left for twats like yourself! Oh thats right thats classed as
    a special location you cant, but then you'd know that wouldnt you?
    I have more qualifications in electrical installations than is needed to be
    classed competent, what about you?
    I bet one of them may even run!
    tosser
    Robs, Jan 3, 2006
  20. deadmail
    Robs Guest
    No its not, just a bit of common dog ****!
    But being a **** wit is a no no, so sorry that's your sparkies career dead
    in the water!
    Robs, Jan 3, 2006
