When replacing bits around the bike's injection system... And you check it before putting the fairing back on... And you find a piece of 'rubber stuff' that's meant to stop heat coming out of the fairing onto your legs... And realise you should have put this in place around the fuel rail before reassembling it... Don't just jam it in around the throttle bodies and fuel rail thinking "that'll do"... 'cos when you start the bike the following morning you'll notice the throttle is slightly stiff. You'll then do the reasonable thing of forcing the throttle open as you pull away... and the throttle bodies will then jam WFO as you descend your steep driveway. You then find you can't cut the bike's acceleration. Thank Ged for kill switches.
