Top Yoke Removal
Discussion in 'UK Motorcycles' started by Dan L, May 26, 2007.
  1. Dan L
    Dan L Guest
    Is this a really big deal?
    I need to get the bloody thing off in order to fit the new bar risers
    which will enable my adjustable Jota Bars to be, well, adjustable.
    Trouble is, the existing risers bolt through from the top, whereas the
    new ones bolt on from underneath.
    Loosening the 2 allen headed screws which clamp the top tubes does not
    worry me, but undoing the big chromium plated domed nut does.
    I am guessing that if I get all these undone, reassembly is the reverse
    procedure, with the added fun of wielding the torque wrench.
    Any pointers?
    Dan L
    http://thebikeshed.spaces.live.com/
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6/7)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, May 26, 2007
  2. Dan L
    <points>
    <waves>
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    '02 MV Senna '03 Tigtona 955i '96 Tiger '79 Fantic Hiro 250
    Krusty, May 26, 2007
  3. Dan L
    Dan L Guest
    Thanks, that's a real help. (no, really)
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, May 26, 2007
  4. Dan L
    Ben Guest
    It's mostly for show that nut. Undo that and the ones on the tubes
    and pull it up. The fork will stay put as the nuts that hold the
    steerer are under the yoke.
    Ben, May 26, 2007
  5. Dan L
    Ben says...
    Wot 'e said
    Lozzo
    Suzuki SV650 K3
    Suzuki GSX-R750L - For Sale £600
    Yamaha 250 Flat-tracker
    I ride way too fast to worry about cholestorol.
    Lozzo, May 26, 2007
  6. Dan L
    Dan L Guest
    Marvellous, ta muchly
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, May 26, 2007
  7. Dan L
    You're very welcome. If there's anything else I can help you with,
    don't hesitate to ask.
    Krusty
  8. Dan L
    Dan L Guest
    Akkshirly there could be.
    The knuckles on my Jota Bars have developed a habit of coming loose no
    matter how hard I tighten them. Should I use threadlock or PTFE tape
    to stop this from happening?
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, May 26, 2007
  9. Dan L
    Eiron Guest
    Take the weight off the front end by using a paddock stand and a jack
    under the engine, to avoid the risk of twisting the bottom yoke.
    Or use a front paddock stand that goes under the bottom yoke.
    Eiron, May 26, 2007
  10. Dan L
    Absolutely.
    Krusty
  11. No doubt you know more about this than me, but I was surprised at how tight
    Haynes recommends it should be tightened - 110Nm. This is not trivial for a
    scrawny soul like me.
    Antony Gelberg, May 26, 2007
  12. Dan L
    Dan L Guest
    Right you are then, both it is. Now, do I apply the threadlock first
    then wrap with ptfe or do it the other way round.
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, May 26, 2007
  13. Dan L
    I would.
    Krusty
  14. Dan L
    Dan L Guest
    All done, your advice was invaluable
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, May 26, 2007
