Torque wrench settings?
Discussion in 'Motorcycle Technical Discussion' started by Bummers, Oct 7, 2005.
  1. Bummers
    Bummers Guest
    Why do manufacturers specify a (biggish) range of torque settings?
    Wouldn't one suffice?
    Bummers
  2. Bummers
    John Johnson Guest
    1. calibration of torque wrenches varies
    2. friction between fastener and hole varies (affecting "felt" torque vs
    "applied" torque)
    2 is the result of:
    a) fastener type
    b) fastener quality
    c) contamination (e.g. with lubricants, abrasives, etc.)
    d)etc.
    Unless the application is critical, you specify a range that works, and
    design a fair margin of error into the components. If the application is
    critical, you start to see torque-to-yeild fasteners or the work gets
    taken out of the hands of people outside of specialist houses.
    Later,
    John
    John Johnson, Oct 7, 2005
