Trackday: Snetterton on Monday 14th Sept, £65
Discussion in 'UK Motorcycles' started by antonye, Aug 24, 2009.
  1. antonye
    antonye Guest
  2. antonye
    darsy, Aug 25, 2009
  3. antonye
    Oh to be a dole monkey.
    I'll have to settle for 9 days of Alpine lunacy instead.
    ogden, Aug 25, 2009
  4. antonye
    booked now, into the novice group.
    well, it's all good.
    darsy, Aug 25, 2009
  5. antonye
    antonye Guest
    Novice? Are you mad?
    antonye, Aug 25, 2009
  6. antonye
    not at all. I'm not nearly fast enough for the "fast" group, and the
    "intermediate" group always appears to be stocked with cunts.
    erm.
    darsy, Aug 25, 2009
  7. antonye
    antonye Guest
    Heh. Seriously tho, Novice will be full of wobbly cunts on their
    first trackday all following each other into the nearest ditch.
  8. antonye
    well, we'll see - I like Snetterton - it's got plently of overtaking
    opportunities. If, by some miracle, I'm too fast for the novice group,
    I'm sure they'll let me move up anyway.
    darsy, Aug 25, 2009
  9. antonye
    antonye Guest
    Very true, and No Limits run a tight ship so you'll be fine.
  10. antonye
    should be. Might need a new rear tyre before then - definitely match
    the BT016 I had put on the front - totally confidence inspiring bit of
    rubber (unlike the D208 that's currently on the back - it definitely
    squirrels around a bit).
    darsy, Aug 25, 2009
  11. antonye
    Nige Guest
    I find it's usually the fast group with the cunts.
    Nige, Aug 25, 2009
  12. antonye
    You'd probably find that with any group.
    darsy, Aug 25, 2009
  13. antonye
    Nige Guest
    wow, that was too easy
    Nige, Aug 25, 2009
  14. antonye
    You'll be very pissed off very soon with the novice group, believe me -
    the standard of riding in novice group is usually fucking abysmal.
    Inters is definitely where you should be
    Lozzo, Aug 25, 2009
  15. antonye
    Predictable cunts at least, which is something the inters and novice
    cunts certainly aren't.
    Lozzo, Aug 25, 2009
  16. antonye
    <Also waves>[1]
    [1]I think I may drop back and do a couple of inters sessions before
    going back up into fast group, because it's been a while since I was
    out on track.
    Lozzo, Aug 25, 2009
  17. antonye
    every track day I've done has been in the novice group. And I'm slower
    than I used to be.
    darsy, Aug 26, 2009
  18. antonye
    Your riding is on a par with mine, you belong in inters.
    Lozzo, Aug 26, 2009
  19. antonye
    well, we'll see.
    darsy, Aug 26, 2009
  20. antonye
    I've changed my booking to the inters. Let's hope it's not too
    embarrassing.
    darsy, Sep 3, 2009
