Transalp front cylinder
Discussion in 'UK Motorcycles' started by Nige, Dec 6, 2009.
  1. Nige
    Nige Guest
    Not running when cold, then just burts into life after a mile or so.
    Just tried it again from cold.
    What the hell could that be?
    Nige,
    BMW K1200S
    Honda Transalp XL600V
    Range Rover Vogue
    Nige, Dec 6, 2009
  2. Nige
    'Hog Guest
    Sounds like.
    Once running is it fine all the way? if intermittent look at the coil.
    'Hog, Dec 6, 2009
  3. Nige
    Pete Fisher Guest
    Repeat after me the following mantra:
    Compression, Ignition, Carburation.
    A cylinder may be 'lazy' for any or all of the above reasons.
    If it really *bursts* in to life suddenly that suggests ignition as the
    most likely culprit to me. Sub-optimal spark not firing mixture until
    everything is properly warmed up.
    Really, you should do a compression test to compare the pots. Then work
    through the ignition components from plug back to CDI unit or what ever.
    Being a twin, you can often swap things about to diagnose the problem.
    Failing that it sounds like it could be a non-operating starter jet, as
    suspected early on IIRC. You could even possibly swap the carbs to see
    if that transfers the problem to the other pot.
    | Pete Fisher at Home: |
    Pete Fisher, Dec 6, 2009
  4. Nige
    Nige Guest
    I think it's summat to do with the carbs. The choke is iffy, i'll get it
    looked at.
    Nige, Dec 6, 2009
  5. Nige
    Nige Guest
    It's fine once it gets going.
    I'm shite with carbs & chokes etc.
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Dec 6, 2009
  6. Nige
    Pete Fisher Guest
    Seems plausible. Have you tried warming it up longer before setting off?
    I would have expected a bit of spluttering and farting from the dodgy
    cylinder before finally chiming in rather than a sudden transition from
    not running at all to firing properly.
    One of the less endearing features of a Morini with Dellortos is the
    impossibility of running on part 'choke'. The starter jet toggles on the
    carbs are independent, and either simply on or off. In really cold
    weather you may need both on to get it to fire at all, but you have to
    put one off fairly quickly or it will be idling far too fast. Even so,
    they don't truly run just on one pot until warm, just a hesitantly at
    low revs and small throttle.
    All much easier to diagnose with a single ;-)
  7. Nige
    'Hog Guest
    Then go to a good one man bike workshop somewhere
    'Hog, Dec 6, 2009
  8. Nige
    Nige Guest
    The odd thing is the thing runs ace when it jumps in, but does it spit & pop
    at the back end, oh hell aye. Once the new exhaust pipe is on Thursday, i'm
    gonna get it looked at.
    The choke lever wont stay in one place & hardly does anything if you do pull
    it.
    I think the chokes are gummed up with some shit.
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Dec 6, 2009
  9. Nige
    Nige Guest
    Aye
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Dec 6, 2009
  10. Nige
    Pete Fisher Guest
    Could be that the tiny drilling from the starter jet circuit in to the
    body is blocked. The pops and bangs may just be due to air leaking in to
    the exhaust system, but if a new pipe with no leaks doesn't cure that it
    may have gummed up idle jets. Does it tick over OK on both pots when
    properly warm? Sir may need access to an ultrasonic cleaner ;-)
  11. Nige
    Nige Guest
    I checked the pipes & they don't blow, sounds like a carb man can do it.....
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Dec 6, 2009
