Tricks to get pre-load on forks.
Discussion in 'UK Motorcycles' started by Toad of Toad Hall, Dec 16, 2003.
  1. I'd like a tad more pre-load on my (non-adjustable) front forks.
    A mate has suggested putting car valve springs in to achieve this effect.
    It occurs to me two metal cylinders of the right diameter would also work.
    Anyone tried this?
  2. Toad of Toad Hall
    Two pence pieces, start with 12p per leg and adjust accordingly.
    sweller, Dec 16, 2003
  3. Toad of Toad Hall
    flashgorman Guest
    In my far off youth, it was the practice to put two ford escort wheel nuts
    in the forks on an elsie. I'm pretty sure you can buy retro fit preload
    adjusters from demon tweaks.
    flashgorman, Dec 16, 2003
  4. Toad of Toad Hall
    mups Guest
    First question, why? Have you tried changing the fork oil. New oil can make
    a huge difference to the suspension without mucking about with the springs
    and such.
    Yep and 2p coins.
    mups, Dec 16, 2003
  5. Toad of Toad Hall
    tallbloke Guest
    (Toad of Toad Hall) spouted the following in
    Might find they are a bit heavy, try big diameter clutch springs and
    washers. You might want to pack 'em bottom and top to keep 'em central.
    Could lead to coil binding and unpleasant bottoming out.
    It's a lot of faff. New springs may be worth the £15 or so.
    tallbloke, Dec 16, 2003
  6. Toad of Toad Hall
    The standard bodge used to be to put some spacers on top of the
    springs.
    Champ, Dec 16, 2003
  7. Toad of Toad Hall
    Alan.T.Gower Guest
    Why? What bike?
    effect.
    Buy some progressive springs and refill with thicker oil.
    Alan
    http://www.ads-training.co.uk
    "Kneesliders Sponsored by Cane"
    GSX-R1000 , Triumph Thunderbird, ZXR750L2 Racer(gone), GS500,
    GHPOTHUF#27
    TGF, UKRMFBC#7, Two#24, BOTAFOF#11, YTC#9, GYASB#1. SbS#23.
    DFWAG#2, DS#2, DIAABTCOD#20. remove "thisbit" in the reply
    http://sportsbike.org (our own endurance team) http://Team-ukrm.com
    "Nemo repente fuit turpissimus"
    Alan.T.Gower, Dec 16, 2003
  8. Toad of Toad Hall
    flashgorman said...
    That's a bit extreme. I used no more than 8p a side in 2p pieces when I
    was running LCs and RDs. It all depended on how knackered the fork
    springs were.
    Lozzo : Old enough to know Champ
    ZZR1100D, GPZ500S, CB250RS x3
    BOTAFOT#57/70a, BOTAFOF#57, two#49(suspended), MIB#22, TCP#7, BONY#9,
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14.
    http://www.glfuk.com/ for MJK Leathers in the UK.
    Lozzo, Dec 16, 2003
