Trident rear caliper
Discussion in 'Classic Motorcycles' started by A.Clews, Apr 28, 2007.
  1. A.Clews
    A.Clews Guest
    I posted a little while ago about the rear brake binding-up on my '93
    Trident. I'd bought a new disk and pads in May last year (did consider a
    new caliper but was quoted some ridiculous price) and had the caliper
    cleaned up (and new seals fitted) by a competent motor-mechanic friend.
    Two or three weeks ago after a 15 mile ride I found the rear disk was nearly
    red hot and the caliper was cooking up nicely too, so obviously the pistons
    were sticking. My mechanic mate recommends (as a first-aid thing) taking
    the lid off the fluid reservoir and using a blunt flat object to apply
    leverage to the piston-side pad so as to force the pistons back down into
    the caliper barrels to free them up.
    Does this seem a reasonable approach? I'm a bit puzzled by the problem
    appearing so soon after last year's overhaul, that's all, though the bike
    hasn't had an awful lot of use over the winter, and it's only done about
    2,500 miles since the brake overhaul. Maybe I should have the caliper
    overhauled again, or maybe bite the bullet and get a new caliper...
    Any suggestions from m'learned friends?
    BTW (TOG?) would I be likely to find spare calipers etc at Kempton Park?
  2. A.Clews
    Yes - make sure the sliding half of the caliper is moving freely. This
    is a common problem on pre-99 Tigers. If some water's got into the
    holes that the sliding pegs go into, a bit of surface rust can bind
    things up, stopping the caliper halfs from moving apart when you
    release the brake pressure.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    '02 MV Senna '03 Tiger 955i (for sale) '96 Tiger '79 Fantic Hiro 250
    Krusty, Apr 28, 2007
  3. A.Clews
    A.Clews Guest
    Thus spake Brian () unto the assembled multitudes:
    Thanks guys (Brian and Krusty so far) for your thoughts. Will have
    another go at freeing it up, but I suspect you are right about getting the
    caliper rebuilt again. I'm seeing my mechanic mate again today so will
    have a word.
  4. A.Clews
    Oily Guest
    Is there any free play at the master cylinder, or is the master cylinder
    returning fully?
    Oily
    Oily, Apr 28, 2007
  5. A.Clews
    A.Clews Guest
    Thus spake Howard () unto the assembled multitudes:
    Hmmm. Had a bit of a full-on weekend (start of the bowling season!) so
    didn't get time to check these points. In any case the caliper's off now
    and in the car waiting to be delivered to my mechanic mate. I'll check the
    other two thingies when I get the caliper back. There definitely seems to
    be a reluctance to move on the part of the pistons, though, even when
    disconnected from the hydraulics.
    Thanks again...
    A.Clews, Apr 30, 2007
  6. A.Clews
    A.Clews Guest
    Thus spake Krusty () unto the assembled multitudes:
    Just to mention that there is no "sliding half" on my Trident caliper; the
    caliper is a single body and the only moving parts are the pistons and
    pads, which themselves slide to and fro on pins mounted through the caliper
    body.
  7. A.Clews
    A.Clews Guest
    Thus spake A.Lee (alan@darkroom.+.com) unto the assembled multitudes:
    Thanks Alan, but my mechanic mate has all the right gear in his workshop to
    get the pistons out. He managed OK last time, anyway.
  8. A.Clews
    A.Lee says...
    I've got a little set up that allows me to pump pistons out on the
    bench. I knocked it up using a ZX-7R rearset with an RF900 m/cylinder
    coupled to a long brake hose.
    Lozzo
    Suzuki GSX-R750L trackbike (Shite with added shite bits)
    Yamaha SR250 Cheasy-Rider (undergoing a transformation)
    I ride way too fast to worry about cholestorol.
    Lozzo, Apr 30, 2007
  9. A.Clews
    Mike Fleming Guest
    Or consider stripping the master cylinder (which I may yet do on the
    Tigger). Those Triumph calipers do tend to seize up somewhat though -
    I bought some spare ones a little while back and had a fun day
    stripping down ten (IIRC) calipers and rebuilding them. Does mean I've
    got some ready-built ones to swap onto the Tigger as I need them
    though.
    Mike Fleming, May 1, 2007
  10. A.Clews
    Mike Fleming Guest
    The caliper itself slides on two pins on the mounting bracket. Those
    can get rusty and seize up.
  11. A.Clews
    A.Clews Guest
    Thus spake Mike Fleming ({mike}@tauzero.co.uk) unto the assembled multitudes:
    Mine doesn't. The caliper is bolted solidly to the mounting bracket.
    There is no movement of the caliper at all. I guess later calipers are
    designed as you describe. Mine is an early ('93) Trident, after all.
    A.Clews, May 3, 2007
  12. A.Clews
    Keith G Guest
    '93 isn't early for a Trident - this is:
    http://www.apah69.dsl.pipex.com/mybikes/Triumph T150 Trident.jpg
    Keith G, May 3, 2007
  13. A.Clews
    A.Clews Guest
  14. A.Clews
    Keith G Guest
    No MP3, but here's a little movie for you (25 secs. @ 8 Mb):
    http://www.apah69.dsl.pipex.com/show/Trident.AVI
    It's very shrill (all tappets and pussy pipes) due to being made with
    only an ordinary digital camera's video function, but it'll probably
    find that filling for you!
  15. A.Clews
    Keith G Guest
    Yesh.
    (Dentures removed, as requested..)
  16. A.Clews
    A.Clews Guest
    Thus spake SpamTrapSeeSig () unto the assembled multitudes:
    Sheesh, talk about a bag of spanners!
    I'm sure it sounded nice going up the road though.
  17. A.Clews
    Keith G Guest
    Don't blame the bike, the sound in *video mode* on the camera used
    (Samsung) was absolutely hopeless - see this clip by way of
    illustration:
    http://www.apah69.dsl.pipex.com/show/Money.AVI
    No bass at all - but the sound on that setup was really quite good!
    I'm sure it would, if No.2 son had blown the damn thing up - head
    gasket, I suspect.....
  18. A.Clews
    Mike Fleming Guest
    My two Tridents are early ones and the Tigger is 1996. They all have
    the slidey 2-pot calipers. Daytona 900 and 1200 have 4-pot calipers
    (same as off one model of GSXR750 IIRC) which bolt direct to the fork
    slider.
    Mike Fleming, May 7, 2007
  19. A.Clews
    Mike Fleming Guest
  20. A.Clews
    Keith G Guest
    What 'kit'..??
    Keith G, May 7, 2007
