Triple Charging
Discussion in 'UK Motorcycles' started by Catman, Jan 7, 2007.
  1. Catman
    Catman Guest
    OK, the speedo stopped working *again*. This is normally a sign that
    the battery is low / dying (apparently).
    This is the second new battery in about 6 months though, so I'm getting
    a bit suspicious.
    It's true that I have heated grips and a loobtronic thing as well as the
    heated gloves / jacket, and the double headlamps, but I tested stuff
    earlier:
    Battery voltage off: 11.9v
    Idling: 12.4v
    Running 3.5k 13 and a smidge
    I'm thinking there is something amiss in the charging system as they
    seem a *tad* low.
    Any thoughts? S Wilson is excused ;)
    www.cuore-sportivo.co.uk
    Catman, Jan 7, 2007
  2. Catman
    That's too low.
    Too low IMHO, but I guess you've got the headlight on all the time?
    Too low. How much was the smidge?
    Did any part of the 'leccy bits say "Lucas" on it? And is there any
    warranty left?
    Timo Geusch, Jan 7, 2007
  3. Catman
    Catman Guest
    Yes and no in that order....
    Catman, Jan 7, 2007
  4. Catman
    Adie Guest
    I had a similar issue with my daytona.
    battery flatter than a pancake. charged it, took it to a shop, they
    replaced the battery. (and didn't believe me when I said i hadn't left
    the ignition on or left it in park)
    battery went flat within a week, took it to a shop, they replaced
    something in the charging system. a sensor or something.
    Lozzo, there may be a receipt or note of what they replaced.
    Adie
    ZX9R
    keeper of the FAQ for my sins
    Adie, Jan 7, 2007
  5. Catman
    Adie says...
    The only electrical item invoiced for is a rear light bulb at the 12K
    service. It might have been a warranty issue and not invoiced for.
    The battery wasn't exactly tip-top when I bought it, but I knew it had
    been flattened just prior to picking it up as the ECU light came on just
    down the road[1] So it sat on the Oximiser for a couple of days until
    the voltage was up to good again. Since then it's been good as new.
    [1] It went off again after the three hot start/stops thing. Had that
    removed from the memory and checked out, everything was fine.
    Lozzo, Jan 7, 2007
  6. Catman
    Not good at all - a healthy, fully charged battery reads around 13.2V
    and if you want to charge one you need to stuff more volts in there.
    I'd expect around 14V on a normal charge.
    Does it climb any higher if you rev it harder?
    Aha, the Prince of Darkness strikes again. Replace with Bosch? ;-)
    OK, first thing to do - charge the battery properly until it reads
    13.2V, then repeat the above tests. Don't forget to measure how low the
    voltage drops when cranking.
    Depending on the outcome check the alternator, rectifier and regulator,
    in that order. Although you probably need a proper workshop manual for
    that.
    Also, check all the connectors between the alternator and the battery
    for corrosion, including the grounding points.
  7. Catman
    GungaDan Guest
    I've been fighting charging problems with my freshly aquired winter
    hack. If you're handy with a multimeter you might find this useful
    (it's a comprehensive fault finding flow chart thingy).
    http://www.electrosport.com/Images/fault_finding.pdf
    GungaDan, Jan 7, 2007
  8. Catman
    Catman Guest
    If the battery was flat, then I'd know there was something more wrong.
    *Everything* works just dandy. Fires up first press, lights flashers,
    all the other instruments. It's just the speedo....
    Catman, Jan 7, 2007
  9. Catman
    Catman Guest
    Never broke 14v. Bearing in mind as well that it spends large amounts
    of time at 4k these days :)
    Bosch makes motorbikes? Perhaps Megnetti Marelli isntead? :)
    Not gonna have time for that this week.
    In fact it's going in for a service this week I hope. I'll get them to
    look at it all.
    Yeah, I'm *hoping* that will be the case. Cheers.
    Catman, Jan 7, 2007
  10. Catman
    Catman Guest
    Cheers for that. Shame I don't have time to do this myself.
    Catman, Jan 7, 2007
  11. Catman
    As long as it's not Ducati Eletrica...
    Probably best course of action but it isn't necessarily a cheap one.
    'leccy fault finding can take an awful lot of time.
  12. Catman
    Catman Guest
    Time is something I have virtually nothing of. Fingers crossed.
    Catman, Jan 7, 2007
  13. Catman
    WavyDavy Guest
    As a numpty of near-but-not-quite BGN status (and that's *after* I went to
    college to study motorcycle mechanics in the 80s......) you might not want
    to listen to me, but shouldn't you also be looking to the output of the
    alternator in Watts versus the consumption of your various gadgets? If the
    alternator pumps out, say, max 500W and your gizmos (plus standard kit etc)
    leech 510(and twin headlights could be 120W+) then you'll always have a
    problem, for example...
    WavyDavy, Jan 7, 2007
  14. Catman
    Catman Guest
    Indeed. The twin lights are OEM. Triumph complied with the EU
    directives by removing two relays. I sincerely doubt they changed the
    alternator. The loobman draws about 20W and all the measurements were
    taken with the heated stuff unplugged. You would be quite right though.
    For the record the heated gloves / jacket draw 120W total, the grips
    about half that.
    Catman, Jan 7, 2007
  15. Catman
    Bod43 Guest
    If you wan't electrical services like that you may need
    a bigger alternator.
    Get one off a car.
    Or even just get a car:)
    You said that you didn't have time to fix it. Do you have time for
    pushing it.
    "If the battery was flat, then I'd know there was something more
    wrong."
    Thing is the battery is flat. 11.x volts is very low. Maybe it won't
    get worse in the short term though.
    Bod43, Jan 7, 2007
  16. Catman
    GungaDan Guest
    Yeah, his point is a good one:
    Jacket 120W
    Gloves 60W
    Headlight 110W (assuming H4s on dip)
    Tail light 5W
    Loobman 20W
    Total 315W
    And that's neglecting sundries such as fuel pump, fan, etc.
    <refers to handily placed BoL>
    alternator output @ 5K revs 390W (CBR thou)
    alternator output @ 5K revs 350W (CBR6)
    OK, different bikes but they're bound to be similarish. So if you're
    pootling, the charging system is going to struggle just to keep up.
  17. Catman
    Catman Guest
    OK it may be low, but it's not like any definition of flat that I know.
    I do have time to pay someone else to fix it.
    Catman, Jan 7, 2007
  18. Catman
    Catman Guest
    That would be 120W for jacket and gloves together. Assuming that the
    10A fuse was being maxed out. Which it isn't
    I'm not. I do 120 miles a day, although top at 4k is 70mph.....
    May have a point, but the issue first ocurred before I fettled the
    lights and fitted the gloves / jacket.
    Catman, Jan 7, 2007
  19. Catman
    Pete Fisher Guest
    Oi, if you are going to slag of Morini electrics get it right - Ducati
    *elettrotecnica*
    | Pete Fisher at Home: |
    Pete Fisher, Jan 7, 2007
  20. Catman
    SD Guest
    480W alternator, apparently. Be glad you don't have a TT600 (300W)
    Sir wants a GL1500 (660W), sir does. Or a Compufire (1325W)
    | ___ Salad Dodger
    |_\_____/_| ..87918../..23274.../..31893.
    SD, Jan 7, 2007
