Triple Charging
Discussion in 'UK Motorcycles' started by Catman, Jan 7, 2007.
  1. Catman
    Catman Guest
    What a *ridiculous* idea ;)
    It might, indeed, but every time it's done this consistently, new
    battery has fixed it.
    Well, it reads 0
    nothing
    not at all
    It's done it before and swapping the battery has immediately brought it
    back to life. There has been a rumour that Triumph admitted it was a
    'feature' to warn of low battery. Better no speedo than no starter. I
    understand that BMWs have a similar 'feature' with the ABS light.
    www.cuore-sportivo.co.uk
    Catman, Jan 7, 2007
  2. Catman
    Catman Guest
    Are they expensive?
    Catman, Jan 7, 2007
  3. Catman
    Catman Guest
    Indeed I do
    Ding.
    Catman, Jan 7, 2007
  4. Catman
    GungaDan says...
    The Triumph handbook for my 2004 Gaytona only says 12V 35A for the
    alternator output. Not much use really.
    Lozzo, Jan 7, 2007
  5. Catman
    SD Guest
    The speedo on that Beemer I hired in NZ went AWOL everytime the
    gearbox got hot. Leave it for half an hour, and it worked fine, for a
    while.
    | ___ Salad Dodger
    |_\_____/_| ..87918../..23274.../..31893.
    SD, Jan 7, 2007
  6. Catman
    SD Guest
    Goldwings? Yes.
    Compufires? About £400. So, yes.
    | ___ Salad Dodger
    SD, Jan 7, 2007
  7. Catman
    SD Guest
    Well, 12 x 35 is 420W, innit?
    'cept I think you're allowed to multiply by 13.5 for some reason,
    which gives 470-ish.
    | ___ Salad Dodger
    SD, Jan 7, 2007
  8. Catman
    SD says...
    I dunno, it took me half an hour to work out what size fuse to put
    inline for my newly fitted heated grips. Maths is not my strong point.
    Lozzo, Jan 7, 2007
  9. Catman
    Catman Guest
    Shame that.
    Catman, Jan 8, 2007
  10. Timo Geusch wrote
    Check the meter is right. The reading all seem going in the right
    directions but all seem to be an equal amount out.
    Checking voltage while cranking is, at best, a poor means to do a
    dynamic test battery. Better is to crank and then look at voltage
    recovery times as there are too many mechanical variables which will
    affect battery performance to make such a test anything other than a
    guide for someone with more than half a clue.
    steve auvache, Jan 8, 2007
  11. Catman wrote
    Which rather suggests the speedo may be at fault, or at least not the
    battery but then again it is automotive elctrickery which, as everyone
    knows, is nothing but a black art.
  12. Catman wrote
    So you haven't done any measurement of the current actually being taken,
    you are just guessing based upon the writing on a fuse?
  13. Catman
    gazzafield Guest
    The same cunts that I read were saying that one of their bikes using a litre
    of oil in something silly like 500 miles was "normal" for an engine.
    gazzafield, Jan 8, 2007
  14. Catman
    This may also sound mental, but could it be that replacing the battery
    wriggles the wiring around enough to temporarily 'repair' a dodgy
    wire/connector/sensor coming from the speedo sensor?
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Jan 8, 2007
  15. Catman
    Catman Guest
    That's a fair point. Every other 12v supply I've used it on reads 12v/
    Well it's going in for its 18k service on Thursday with instructions to
    have a look....
    Catman, Jan 8, 2007
  16. Catman
    Catman Guest
    Well at the time, the current being drawn was 0.
    Catman, Jan 8, 2007
  17. Catman
    Catman Guest
    Yes, indeed.
    Catman, Jan 8, 2007
