TRX 850 master cylinder noise + mushy brakes ?
Discussion in 'Australian Motorcycles' started by sarcasmatron, Mar 3, 2004.
  1. sarcasmatron
    sarcasmatron Guest
    Gday . I've just lobbed onto this group after buying my first decent bike -
    a nice TRX850 with magnum pipes (oh joy *slobber slobber drool* what a
    freakin' delicious sound !) . I thought I'd open by nagging youse with a
    question . The front brakes tend to pulse as the bike comes to a complete
    stop (ie the last few metres) but are fine when doing the main braking . It
    feels like they're grabbing and letting go about once a second and is
    extremely noticeable . The lever also feels pretty mushy . I also noticed
    that as soon as you touch the front brake lever when still at speed , there
    comes forth a sound from the master brake cylinder on the bars . A high
    pitched sound like water being emmitted from a small hole in a hose - not
    entirely unlike the bizzing sound an electric circuit makes when being
    shorted out .
    Now I took it back to the dealer who reckons the brake line needs to be bled
    .. He also claims that "a lot of sport bikes make that noise under braking" .
    This sounds extremely suspect to me and I am guessing that he will keep
    feeding me this line until the warranty runs out , at which point the noise
    will suddenly and uncannily indicate a shagged master cylinder .
    Does anyone else have a perfectly good sport bike that loudly buzzes under
    front brakes ?
    Ta for any info , you selfless , caring , sharing people . Feel free to tap
    into my extremely and possibly critically-limited motorcycle experience .
    Lee.
  2. One or both of your front discs could be warped. It'd be a completely
    separate problem to the possibly shite state of your brake fluid, which
    should, as a matter of course, be changed every few years at most. If
    anything, I'd be beating the dealer about the head to do it under warranty,
    as they shouldn't've sold a bike with shit brakes.
    This pulsing you describe, is it just a sound, or can you actually feel it
    at the lever when you brake?
    Get your bike and push it around the carpark at work or up and down the
    driveway at home and see if the discs make a sound in phase with the wheel
    rotation
    (silence-silence-silence-scccchhhhkk-silence-silence-silence-scccchhhhkk...)
    .. If they do, and the *sccccchhhkk* is appreciably loud, you're up for new
    discs. Sorry.
    Intact Kneeslider, Mar 3, 2004
  3. sarcasmatron
    sarcasmatron Guest
    Cheers for the reply . The brakes don't make any pulsing *sound* (it's the
    master cylinder that makes the whistling sound) , they just feel as if I'm
    letting go and reapplying them once a second , which makes the bike surge
    and slow , surge and slow ... I don't seem to recall the discs making any
    irregular scraping sound as I pushed it around (it's at the dealer now)
    because I deliberately listened to it .
  4. sarcasmatron
    X-No-archive: yes
    sarcasmatron wrote in message
    I've never heard a master-cylinder make a peep so I've very curious about
    yours whistling!
    Clem
    Knobdoodle, Mar 3, 2004
  5. sarcasmatron
    alx Guest
    I'd take it back, urgent safety issue. Warranty also.
    Disc/s are warped.
    Dont fancy braking hard in slippery/wet conditions. You'll be on your backside.
    alx, Mar 3, 2004
  6. That's fairly normal (the buzzing sound, especially if the brakes are
    wet - like just after washing the bike). Both my Blackbird and the
    Busa have done it.
    Cheer
    Kevin Gleeson, Mar 3, 2004
  7. sarcasmatron
    X-No-archive: yes
    Kevin Gleeson wrote in message ...
    I've certainly heard callipers/pads buzz (and screech, squeal, whine, grind,
    graunch, click, clunk, clack and clatter) but I've never heard anything out
    of the master-cylinder!
    Clem
  8. I am assuming that it just appears to be coming from the master
    cylinder, that buzzing pad noise is pretty normal. Unless of course it
    is from the master cylinder, then I'd definitely be worried :)
    Cheers
  9. sarcasmatron
    FuTAnT Guest
    You have to have the brakes slightly applied to get the full effect of a
    disc warp. It sounds pretty much certain that one of both of your discs are
    slightly warped. I've had a bike like this before and it didn't worry me too
    much, no big hassle. The holes in the discs to lighten them etc will make a
    noise when braking, but most bikes are like that, and it shouldn't be that
    audible.
    BTW, how did you KNOW it was from your master cylinder?? Sounds bounce
    around a bit, so it is more likely to be from your front discs themselves,
    it seems quite odd that the master cylinder would be making any noise at
    all. It's just a piston pushing fluid .. what the??
    Cam
    '03 954
    FuTAnT, Mar 3, 2004
  10. sarcasmatron
    Johnnie5 Guest
    you know they need new pads every now and again
    Johnnie5, Mar 3, 2004
  11. sarcasmatron
    Dr.Shifty Guest
    If my discs play up the master gets really agro and yells out, "Don't make me
    come down there"
    Kim
    Dr.Shifty, Mar 3, 2004
  12. sarcasmatron
    TB Guest
    Besides the Seals and the springs scraping in there, there's nothing that
    can make that kind of a noise in a master cylinder to the best of my
    knowledge. The fluid's not under that much pressure to make such a noise and
    if it was, you'd be looking at new paint work on the bikini fairing too..
    Sounds very much like a warped disc(s), which could be sending feedback into
    the lever if they were warped in sync. I agree with the rest, get it
    replaced ASAP. Brakes are more important than engines IMHO..
    TB, Mar 3, 2004
  13. sarcasmatron
    alx Guest
    But one quick and useful check/fix:
    Grab some spraycan brake cleaner.
    Spray into/around every floating rivet on each disk.
    As you do each rivet, get to with the fingers and ensure the floating rivet is nice and relaxed and floating.
    I had the same symptoms as a warped disc but a dial gauge confirmed all in order.
    Some/one of thr floating rivet mounts was not as floating as it should have.
    alx, Mar 3, 2004
  14. sarcasmatron
    Black Bart Guest
    I had similar symptoms when I had new front discs put on
    my bike. Front end would judder and the lever would pulse
    under brakes. You could even see where the warp was from
    the blueing of the steel from the friction of the pads.
    Took it back and they checked the discs and they weren't
    warped in the slightest. Refitted them and they were fine.
    Seems some shit made it's way between one disc and the
    rim when being fitted so there was a high spot.
    Black Bart, Mar 3, 2004
  15. sarcasmatron
    sarcasmatron Guest
    cheers I'll check it when I get it back
  16. sarcasmatron
    sarcasmatron Guest
    You can't notice anything under light braking . It is only when the bike is
    pulling up for the last few metres that there is *any* efect at all .
    Certainly sounds like it was coming from the BMS . I got my head dangerously
    and stupid-lookingly close to it .
  17. sarcasmatron
    sarcasmatron Guest
    Yeah , obviously . But over the usual verbal instructions/complaints from
    one part to its cohorts , the buzzing can still be heard .
  18. sarcasmatron
    Eleven is perfect on a green one.
    (Hey sarcasmatron; how about you leave in the bit of the previous post to
    which you are referring... And the "Fred wrote:")
    Clem
  19. etc
    yer disc/s are warped
    the sound is from the pad/rotor interface and is fairly normal if rotors are
    slotted/drilled
    mushy (lever is 'spongy', pumping improves feel) is from air in line
    excess lever travel (differentiated from mushy as lever gets 'hard')is from
    disc warp as pads get pushed back further than designed for
    get it fixed under warranty as discs are expensive...try not to accept
    straightening as a solution as disc will most likely warp again after a few
    good temperature cycles
    fulliautomatix, Mar 3, 2004
  20. sarcasmatron
    GB Guest
    Are we talking whistling dixie here, or more popular tunes,
    or what?
    G
    GB, Mar 5, 2004
