turn out pipe ends
Discussion in 'UK Motorcycles' started by Hairy Arse, Nov 23, 2004.
  1. Hairy Arse
    Hairy Arse Guest
    Being the chromosexual i am, i'm trying to make the virago look even more
    gay :)
    I want to make the exhausts into turn out pipes, simpelist way to do this
    i've some up with is to slot in a length of chromes tube.. suitable bent at
    the end to produce the required look.. kinda like those turn down exhaust
    end finishers for old cars,
    The reason i dont just use 2 of them is they only go upto 54mm in diamiter..
    cars have small exhaust pipes.. and most shops only sell the wide boy
    exhaust ends that mount onto a 1 inch pipe and make it look like it's really
    a 6 inch pipe.. complete with twatty blue led's and all that :)
    Does anyone know where i can get either some 66mm outside diamiter turnouts
    from.. really cheap.. so i can chop the ends off and slip them up my
    existing pipes,
    or some turn out ends.. i know highway hawk sell some.. but they are 70mm
    diamiter or so.. and bloody 45 quid each,
    Failing that, ant other suggestion on where to get something suitable.. i'm
    thinking exhaust end can ends maybe.. but the tube needs to be exactly 66mm
    diamiter.. and have about 5 inches on the straight part.
  2. Hairy Arse
    Tealc Guest
    why dont you use one of theose 90 degree Pipe bends for drain pipes??
    Tealc, Nov 23, 2004
