As header. 1400 failed it's MoT today as both sets of brakes were very spongy, with too much travel. Pads are fine so almost certainly air in the system, I are told. ( He was fine with the exhausts,which was a result ) . So, I did a quick google to see what UKRM had previously said on this, and got this from TOG in Feb 03: ++++++++++++++++++++++++++++++++++++++++++ To bleed the brakes: attach piece of bleed pipe to bleed nipple. Put other end of pipe in glass jar. Pump lever half a dozen times, and then pull in. Without releasing lever, open bleed nipple. Close nipple. Release lever. Pull in lever. Open bleed nipple. Close nipple. Release lever. Pull in lever. And so on and so on, remembering to top of the fluid reservois as you go. When no bubbles come out of the pipe and the lever feels firm, it's done. +++++++++++++++++++++++++++++++++++++++++++ Now, that seems easy enough. Just a quick question - before I do this, do I remove the appropriate cylinder cover for the brake I'm working on? Also, is the pipe/jar interface just to stop brake fluid hitting the paintwork? Finally, is this the 15 minute job it suggests or could I be there for hours deopending on amount of air in system? If it helps, when I press the rear pedal as is I hear a slight knocking sound - would that be the pistons trying to move out? Ta in advance, as always.
