Tyre Pressures
Discussion in 'UK Motorcycles' started by Krusty, Jun 30, 2009.
  1. Krusty
    Been having a mooch around tyre websites, & noticed something that's
    baffled me a bit. Take Pirelli for example; they recommend the Diablo
    Corsa III for the MV, with 2.3 bar front & rear. Yet for the same tyre
    & size on the Jap 750s (GSX-R, R7 & ZX-7R) they say 2.5 bar front & 2.9
    bar rear.
    I can't figure out why there'd be such a big difference on the rear for
    the MV, bearing in mind the fairly similar weight & power output. Any
    ideas?
  2. Krusty
    Stupid boy.
  3. Krusty
    Simon Wilson Guest
    Jap bikes are ridden by fat(ter) bastards?
    Simon Wilson, Jun 30, 2009
  4. Krusty
    Wild guess #1: it's lighter/carries its weight further forward than
    other comparable bikes;
    Wild guess #2: it's more powerful and more likely to run the rear tyre
    hot;
    Wild guess #2a it's even more of a sports toy than other bikes and
    likely to be ridden harder, thus more likely to run the rear tyre hot;
    Really Wild guess #3: the rear suspension needs to work with a softer
    tyre spring rate for some reason.
    Pip Luscher, Jun 30, 2009
  5. Krusty
    2a - unlikely imo. 1, 2 & 3 had all crossed my mind (3 because the
    standard suspension settings are harder than typical Jap bikes), but it
    just seems like too big a difference, even taking all of the above into
    account.
  6. Krusty
    ts Guest
    Different wheel/rim material? Or profile?
    Quote from Ducati SS owner's Manual: "To avoid front wheel rim
    distorsions when riding on bumpy roads, increase tyre pressure by
    0.2-0.3 bar"
    Yes, it was _front_ rim distorsion, but it may have to do with different
    profiles; the Duc 750 SS should have a 60 profile and the 900 a 70 one
    on the same wheel dimension. Several 750 SS owners I know of have had to
    have their front rim straightened.
    ts, Jun 30, 2009
  7. Krusty
    That's gender reassignment surgery, right?
    Pip, Jul 1, 2009
  8. Me and Bruce, for starters.
    The Older Gentleman, Jul 1, 2009
  9. Krusty
    Doki Guest
    I suspect it's all about wheel rate. Tyre pressures make a big difference to
    what forces the suspension recieve. Same thing as some tyres suiting some
    models fine whilst being naff on others - the carcass strength affects the
    wheel rate.
    IIRC Caterham found several seconds a lap after trying their stock tyre and
    wheel combo on a chassis dyno, and getting some tyres that actually suited
    the suspension.
    Doki, Jul 1, 2009
