Tyre size measurements
Discussion in 'Motorcycle Technical Discussion' started by Ben Halicki, Dec 27, 2004.
  1. Ben Halicki
    Ben Halicki Guest
    Hi all,
    When a tyre is marked 100/80, what do those numbers relate to? I
    understand they determine the width of the tyre, but at what points?
    Thanks in advance,
    Ben.
  2. Ben Halicki
    PQ Guest
    1st hit in Google was:
    http://www.chris-longhurst.com/carbibles/index.html?menu.html&tyre_bible.html
    "100" Section Width: The width of the tyre in millimetres from sidewall to
    sidewall. This measurement varies depending on the width of the rim to which
    the tyre is fitted: larger on a wider rim, smaller on a narrow rim. The
    number on the side of tyre indicates the width measured with the tyre fitted
    to the recommended rim width.
    "80" Aspect Ratio: The ratio of height to width; this tyre's height is 65%
    of its width.
    PQ
    PQ, Dec 27, 2004
  3. Ben Halicki
    PQ Guest
    Correction:
    PQ, Dec 27, 2004
  4. Ben Halicki
    Ben Halicki Guest
    Thanks for that info PQ, now I understand. Great site too, lots of useful
    info!
    Cheers,
    Ben.
    Ben Halicki, Dec 29, 2004
