Tyre slime...
Discussion in 'UK Motorcycles' started by Nige, Oct 31, 2010.
  1. Nige
    Nige Guest
    Anyone use this in car tyres just in case, the MX5 has a small enough boot
    as it is, so would like to dump the spare.
    Any issues?
    Nige
    R1
    MX5
    Nige, Oct 31, 2010
  2. Nige
    Pete Fisher Guest
    You mean relying on pre-filled slime IYSWIM, or a pump and slime kit
    once you have a puncture?
    Neither will cope with a severe alloy wheel rim/kerb interface.
    DAMHIKIJDOK.
    | Pete Fisher at Home: |
    Pete Fisher, Oct 31, 2010
  3. Nige
    Nige Guest
    That green shit, i was gonna put it in the tyres as a precaution..
    Nige, Oct 31, 2010
  4. Nige
    Nige Guest
    Cheers fella...
    Nige, Oct 31, 2010
  5. Nige
    Colin Irvine Guest
    Quite. I like to know as soon as I start losing air.
    Colin Irvine, Oct 31, 2010
  6. Nige
    Me too.
    Lozzo
    they churn out)
    Lozzo, Oct 31, 2010
  7. Nige
    Pete Fisher Guest
    In communiqué
    I agree, but it reminds me that I was going to see if I could source
    some cheap winter wheels/tyres for the Mazda 6 as we may use it do go on
    a self drive skiing holiday next February. I have snow chains for it,
    but from how it behaves on wet grass I suspect it will be nothing like
    as competent in just light snow as the diesel Octavia was. One of the
    winter wheels could also act as a get you home spare. There's space
    under the floor presently filled with a plastic foam moulding which is
    occupied by various tools and the emergency tyre inflation/sealing kit.
  8. Nige
    are you talking about using it for emergencies or fitting as a proactive
    measure?
    If the former then no problem. It is commonly used by cheapskate
    manufacturers as a spare wheel substitute.
    I'd only do the latter if you are considering joining Bonwick across a
    desert.
    Although, I had a lump of metal in my rear tyre last year. Only a month
    after getting it new. I whacked in a can of Wynn's Tyre Fix (supplied by my
    tyre fitter so he knew it was there when I had a new tyre and it didn't
    create any ghostbuster's moment) then rode a couple of thousand miles
    around Europe and commuted for several months.
    wessie, Oct 31, 2010
  9. Nige
    Ian Field Guest
    It'll dry out and form little tumbleweeds by the time you get a puncture.
    Ian Field, Oct 31, 2010
  10. Nige
    see dnc's post - Slime won't set which is what Nige is contemplating.
  11. Nige
    Ian Field Guest
    Is that any better than the Holts Tyre weld?
    Last time I used Tyre weld I had to jam a twig in the hole to stop the foam
    gushing out.
    The local bike shop sells obscure brand cheap Chinese stuff that's slightly
    better at gunging holes but the adaptor hose was faulty on the last one.
  12. Nige
    No idea, only other one used was Finnlec which was overwhelmed by the
    slashes from the glass I rode over and the lack of rubber left on the tyre
    to seal. Got me 70 miles home riding on 15psi though.
    They won't seal big holes for that very reason as they rely on clotting. A
    bung type repair was probably a better bet for you.
    For me, the spiky object went into the tread at an angle, mainly through
    the very deep tread block of the new tyre. There was only the slightest
    leak so it sealed it good & proper.
    My tyre fitter & service bod gave me another can of the Wynn's as a freebie
    after the major service he did last month. It's only a fiver a tin anyway,
    so worth carrying as it is less faff than fitting bungs, and makes you very
    popular with mates who get unlucky.
  13. Nige
    Used it in many bikes & it's always worked a treat, even with tubes.
    Krusty, Nov 1, 2010
